reddevil0728
Context
- House is wired up with CAT6
- Currently using TP-Link Archer AX72
- Coverage at home is bad
- In a previous house, my setup includes a more powerful router as the main router, with 2x less powerful router in Access Point mode connected to the main router via CAT6.
- This was before the era of Mesh Network
- Initial intention is to do a similar setup in the new house, but instead of getting 2x less powerful router, which is not aesthetic pleasing (and those that are, would not be of good specs) to use with the existing Archer AX72, looking at Mesh (e.g., TP-Link Deco X68) which I understand that can work as an AP and can be wired to the main router (in this case Archer AX72).
- I realised from this write-up, it seems like mesh network with wired backhaul has seemless handoff but Router + AP may not be. Is that the case?
- If the above is the case, does it make more sense to just dump the AX72 and get a 3-pack mesh nodes and use it with wired backhaul?
- Or would it be better to just keep the AX72, and then get a 2-pack mesh nodes and use it in AP mode but connected to AX72 via wire?
- Or any other more elegant solution that makes sense?
