Where can I download 3.0.0.4.276 for N66U?
Based on I downloaded and installed it as a test.
Safe to the hardware is not the same as safe for the user or network it is running on.
I understand the use of the old firmware. I too want to experiment with it and see if it improves stability with my older devices.
No, my point is that it may not be the firmware you think it is... it may have been modified by anyone.
Guess I should have also mentioned that I had the firmware from Asus on a backup drive and compared date & md5 with the file at the link which matched.
G Where is my Guest Network UI tab? Facebook??? ASUS N Routers & Adapters 4
