Where to download n66 merlin 3.0.0.4_270.26b?
Ksmith
I have heard this is a stable and very good with connectivity. I can't find it on his site, can anyone post a link to where I can download it? I have the N66u Router.
Firmware 3.0.0.4_270.26b is the firmware I am looking for.
Thanks if anyone can find it.
I want it too! Where can I download that?
Not a good idea.
That's old and a lot of security patching has been done as well.
Get Merlins latest, same WiFi range on the RT-N66U compared to the old SDK5 versions.
Not a good idea.
Which of recent merlin & asus original works best?
I have tried them both and they first works fine but after a while they get worse!
Merlins latest is 374.40
Up and running for 3 days on my RT-N66U.
Seems stable here.
No clue about Asus stock firmware.
Never used it.
What do you see getting worse?
Even though it has security flaws if someone has it could they please post a link to download it at?
I found them they were in the Archived section of his download page.
There are two different versions of this firmware, which one are people talking about, the dwrp.zip one in the experimental folder or the regular one in the regular folder?
What does dwrp mean?
http://www.mediafire.com/download/c87a2qf920vi2cg/RT-N66U_3.0.0.4_270.26b.zip
http://www.mediafire.com/download/5w0vbv9gibgyw2a/RT-N66U_3.0.0.4_270.26b-dwrp.zip
dw = DualWAN
rp = Repeater mode
yd = YandexDNS filtering
ksmith
What is daul wan sorry for my ignorance. I just use it to connect to my computer in the upstairs reliably.
Is one better than the other?
It's for when you have 2 internet connections coming in to your prem. You can set the router up to load balance or failover between them.
Those older archived versions will not work on the newer RT_N66U revisions, which uses a different type of flash memory. That's the reason why they were archived, and those older RT-N66U builds are in a folder clearly labelled that they are for Revision B1 only. Flashing it on a newer revision will soft brick your router, requiring the use of the firmware recovery tool from Asus to flash a compatible version again.
