DarkKnight75
One of the many reasons i wont upgrade to an AX router nor do i have any AX devices....I plan on using my AC86u for foreseeable future and upgrade to AZ in 5 yrs..lol
Initially, had an old laptop that would not connect to my AX88U. I had to update the drivers on it. Also, my 2nd gen Firestick would not see 5ghz signal so I had to change the control channel to 36. I believe channel 48 plus others work as well but I haven't tested.my tablet some times does not connect on 2.4
my isp even had way better signal strength than the 88ax has
I don't install routers for a living. I buy consumer oriented equipment and put it where I have power and connectivity. My past routers have all run the things I've asked them to run. You contend that is not enough, that I need to spend hours tweaking this and that to get juuust the right settings. Perhaps replace the devices I want to use with the router if needed.
I think not, I'd get a different router personally.
I have an RT-AX88U at one end of the apartment, and at the complete opposite end (going through 4 walls), I have no problem connecting to 5 GHz with my tablet (and I can see a stronger signal than I did with my last few routers, which were an RT-AC88U and an RT-AC87U - can't remember how they compared to the previous RT-AC68U). The Roomba is also at the complete opposite end of the apartment (going through four walls at a diagonal angle), and zero problem staying connected to the 2.4 GHz band. I've seen it report multiple days of connection time on the Wireless Log, which means it never ever disconnects (which is quite surprising considering the microwave oven is actually fairly close to the Roomba).
@sturmstar if you haven't used a new SSID when testing new routers, that may one reason why the old one seems so much better.
Are your 'AX88U and the 'AC68U really side by side? What channels are they broadcasting on? I am assuming they are on different SSID's, correct?
When devices going into power saving mode/standby in the system log it shows them as 6/866 for example.A1.0 mine can be good some days link speed some times can be rubbish write down to 6mbs i am on fiber
Welcome To SNBForums
