News WiFi 7 by 2024 for Intel equipped laptops.
It's going to be interesting to see what the silicon vendors provide on the router SoC's...
The potential bandwidth needs for WiFi 7 (up to 40 Gbps) will push all interfaces, from PCI-e to DDR to MII's out to the switch and internal buses...
You can already see the specs for Broadcom's SoC here. Lots of bandwidth added to the Ethernet side of things:
  • Integrated 10/5.0/2.5G multi-Gig phy for WAN or LAN
  • 3x USXGMII Ethernet ports
  • Quad integrated GbE PHYs
That would open the door for quad 10 Gigs Ethernet.
I'll finally be able to upgrade the RT-AX89X plus 2 X GT-AXE11000 setup currently used for 10Gbps fiber broadband...
Getting more options in the N-Base-T and Wireless adapters would be great - that's been a pain point for many if things are not directly built in the the laptop/desktop space...
Router silicon and radios are ahead of the game there (good thing), but recent experience with WiFi-6e (choice of one) and 2.5/5Gbit add-in boards (choice of q couple) is very limiting...
I've been using Thunderbolt 3 10Gbe ethernet adapters (backward compatible) in place PCI-E network cards/adapters. There're also a number of them for 2.5Gbe and 5Gbe from Sabrent, Plugable, QNAP, Caldigit, OWC etc. Only the 10Gbe adapters require a Thunderbolt 3 port on your PC to work. The rest are compatible with USB C 3.2 ports. If you want something that runs cooler (NBase-T adapters tend to run hot) QNAP and Sonnet both sell Thunderbolt 3 to SFP+ 10Gbe ethernet adapters as well. But that'll mean buying a switch with SFP+ ports to use with them.
As for wireless USB dongles/adapters, unfortunately they're all Wifi 6 dual-band MU-MIMO at the moment. Plenty of Wifi 6E PCI-E network cards from Asus, TP-Link and WavLink out there on Amazon though.
