wifi icon on top right missing if one of the bands is disabled.
lgkahn
not sure if it was there in last version.. or if this is by design.. but i recall in the past the icon was there only 1/2 green instead all green..
just noticed now it is missing on both my routers that have one of the bands disabled..
thanks
also it is still usefull when there because you can hover over it and quickly see want channel and bandwidth each band is.. even with one disabled my thoughts is it should be there.
Switch to non-ROG version and see if the icon is there.
thanks hesitant to do that as i have a lot of tweaks configured including custom scripts running at boot and vpn up events.
You can switch between ROG and non-ROG without any problem, just make sure to flush the browser cache afterward. The firmware code itself is identical, so there won't be any impact on your saved settings.
