WiFi Performance
Can you post the output from System Log/Wireless Log while you have your test client connected? (remember to block out your MAC address).
EDIT: Collin and I obviously think alike
Perhaps it's overheating. What temperature do you have shown at Administration > Performance tuning? I get 54 degrees C (I have 5GHz turned off BTW)
How about System Log > Wireless Log?
SSID: "Enterprise"
RSSI: 0 dBm	SNR: 0 dB	noise: -82 dBm	Channel: 1l
BSSID: BC:EE:7B:C3:78:A8	Capability: ESS ShortSlot
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
HT Capable:
	Chanspec: 2.4GHz channel 3 40MHz (0x1803)
	Primary channel: 1
	HT Capabilities:
	Supported MCS : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 32 ]
Mode	: AP Only
49-51 degree's depending on GHz
Will be tomorrow now chaps - been working on this for around 5 hours, time for bed.
Put my old router back on for the time being as I work from home & need a stable/decent net connection (hence the purchase in the first place lol).
Cheers
Chris
Cheers
Chris
You also could try setting 2.4 Ghz to 20 Mhz if you have a lot of routers near you.
I tried that as well - changed from 20/40 to just 20 - same problem.
Only 2 routers in range, 1 on channel 1, the other on 11. Tried auto channel (put me on 6 as expected) & also hard set channel 6 too - no change.
Nothing I've done changes anything.
Do the 2.4GHz signal & 5GHz signal come from the same aerial ? I may swap them around to see if one is damaged ? Clutching at straws here lol
Think I've solved my issues now :)
Probably not one for this section of the forum, but I reflashed with the latest Tomato firmware & I'm getting full signal on both frequencies in the same room as the router & also max speeds.
Signal still drops to around 65% in the next room, but the speed has increased to around 25MB.
I am seeing a full signal in the far corner of the next room though where I previously had a dead spot, so may just need to fiddle with the antenna's a little.
Thanks again for the input guys.
Chris
