Wifi Schedule doesn't work on Merlin 380.64
I have got it working again but held off posting in case (like last time) it stopped working again. It has now worked without issues for over a week.
This is what I did - not sure which part fixes it:
1. For both WiFi schedules turn all times on (so that the grids are all white). Apply
2. Disable both WiFi time schedulers. Apply
3. Flash 380.63_2
4. Flash 380.64_2
5. Flash 380.65_B1
6. Turn both the WiFi schedulers back on and set required on/off times. Apply
I have since updated to 380.65_B3 without issue.
I hope that this works for you too.
HB
3. Flash 380.63_2
4. Flash 380.64_2
5. Flash 380.65_B1
HB
Thank you,I've tried but nothing changed...I'm thinking to flash the original CFE maybe the modification causes this :(
As I posted, the scheduler works fine for me under 380.64. Make sure you wipe any existing settings as explained in my previous post, and that your router's clock is properly configured.
Hi, I tried your code. But it just didn't work.
Does this "reboot" the wifi like turn it off and back on like router reboot would? if i say set this to 5-6am every day ? as rebooting router tend to fix it things when said wifi device is connected to router but has no internet. which only done once week, and i perfer to just reboot wifi 2g/5g over rebooting router.
or does this just leave wifi up and deny connections? like say parental control would?
I will answer my self??
I set this every day 5am-6am to deny , which disconnects all clients and they dont reconnect to after those hours, so I am gona assume this turns OFF wifi for those hour then turn back on? or is just disconnecting clients for those hours and denying all connections and leaving wifi on?
