johnantonio
I have an issue with RT-N66U which runs the merlin firmware 380.63
While there are several devices connected to the 2.4 GH Wifi connection, suddenly WIFI stops working on one of the devices( it can be any of them, smartphone or ipad)
The device is still connected to the 2.4 ghz network but the internet isn't working.
The issue is resolved when I toggle the wifi ON/OFF or reconnect to the same network, in a matter of seconds. This happens 3 or 4 times per day.
When the Wifi signal drops on one particular device, the other devices that run on the same network run perfectly fine.
Both 2.4 and 5 GHZ networks are active, but all devices are connected on 2.4Ghz.
( 2 ipads, 1 laptop, 2 smartphones) .
As suggested here on the forums, I changed the "DHCP query frequency" setting from "aggressive" to "normal", with no results.
The sudden WIFi drop was also happening on the original firmware.
My internet provider is : RCS RDS Romania
Any help or advice would be greatly appreciated, especially from RMerlin user.
Printscreen of a recent Log:
https://www.dropbox.com/s/xeibk1j6wsx0pwl/log.jpg?dl=0
