juanantonio
You were right, I' ve done exactly what you said and I have access from my remote wg client both to LAN and to Inet through my VPN supplier, as I wanted.in my opinion, wg21 rules (dont really know what wgm is doing about these) could probably be deleted. both of them.
as you have a passthru rule, it would make wg11 rule 2 obsolete (it also looks like its ips are missing the last .1, dont know how the system react to this), as this is already included in the passthru rule.
so, hopefully at the end you should have your passthru rule and a single WAN rule (#6) to take care of routing LAN to Server. Nice and neat!
But as you dont have any rules for LAN ips to use VPN I dont really understand why your routing rule is at all needed... but as long as it works and its needed, just leave it there.
Bash:
E:Option ==> peer wg11 rule
ID Peer Interface Source Destination Description
6 wg11 WAN Any 10.50.1.1/24 LAN to WG Server
WireGuard® ACTIVE Peer Status: Clients 1, Servers 1
E:Option ==> peer wg21 rule
No RPDB Selective Routing/Passthru rules for wg21
Thanks a lot!
Edit: Sadly, I had to add the rules I previously deleted, because my wg clients had no connectivity out of the local network.
So, in the end, the rules rest as follows. I include them in case someone else can need help:
4 wg21 WAN 192.168.1.1/24 10.50.1.1/24 WG Server to LAN
5 wg21 WAN 10.50.1.1/24 192.168.1.1/24 WG Server to LAN
E:Option ==> import
***********Some stuff about server and clients.... **********
Server Client Passthru
wg21 wg11 10.50.1.1/24
