@kamoj
Applied 2 min delay for wireguard but still no internet.
2020-04-26 07:58:54 [OpenVPN] WireGuard Client 8681: 824.58:=============================================================
2020-04-26 07:58:54 [OpenVPN] WireGuard Client 8681: 824.59:Information: Check that WireGuard Client is installed
2020-04-26 07:58:54 [OpenVPN] WireGuard Client 8681: 824.61:Information: Check that WireGuard Client is enabled
2020-04-26 07:58:54 [OpenVPN] WireGuard Client 8681: 824.62:Information: Check that a configuration file is given and exist
2020-04-26 07:58:54 [OpenVPN] WireGuard Client 8681: 824.63:Information: Check if not router mode
2020-04-26 07:58:54 [OpenVPN] WireGuard Client 8681: 824.65:Information: Check that the Netgear OpenVPN Client is not enabled
2020-04-26 07:58:54 [OpenVPN] WireGuard Client 8681: 824.66:Information: Check that an OpenVPN Client is not running
2020-04-26 07:58:54 [OpenVPN] WireGuard Client 8681: 824.69:Information: Save default route to restore in case of wg crashes
2020-04-26 07:58:55 [OpenVPN] WireGuard Client 8681: 824.70:Information: ip route before starting wireguard
2020-04-26 07:58:55 [OpenVPN] WireGuard Client 8681: 824.72:default via 172.16.10.217 dev ppp0
172.16.10.217 dev ppp0 proto kernel scope link src 195.213.36.62
192.168.1.0/24 dev br0 proto kernel scope link src 192.168.1.1
239.0.0.0/8 dev br0 scope link
2020-04-26 07:58:55 [OpenVPN] WireGuard Client 8681: 824.73:Information: Check if wireguard is already running, and stop it if so
2020-04-26 07:58:55 [OpenVPN] WireGuard Client 8681: 824.75:Information: Check if wg0 interface is already available, and stop it if so
2020-04-26 07:58:56 [OpenVPN] WireGuard Client 8681: 825.96:Information: Check that all needed data exist in the configuration
2020-04-26 07:58:56 [OpenVPN] WireGuard Client 8681: 826.31:Information: Sleep 120 sec before starting, because wireguard_client_delay is set in NVRAM
2020-04-26 08:00:56 [OpenVPN] WireGuard Client 8681: 946.32:Information: Check that DNS service is working
2020-04-26 08:00:56 [OpenVPN] WireGuard Client 8681: 946.43:Information: DNS service is working
2020-04-26 08:00:56 [OpenVPN] WireGuard Client 8681: 946.44:Information: Check that time is synchronized
2020-04-26 08:00:56 [OpenVPN] WireGuard Client 8681: 946.45:Information: NTP time service is working.
2020-04-26 08:00:56 [OpenVPN] WireGuard Client 8681: 946.46:Information: Time is OK
2020-04-26 08:00:56 [OpenVPN] WireGuard Client 8681: 946.47:Information: Starting WireGuard client: /etc/wireguard/config/client/client_2.conf
2020-04-26 08:00:56 [OpenVPN] WireGuard Client 8681: 946.48:Information: IP of EndPoint myserver.dyndns.org is 2.49.147.209.
2020-04-26 08:00:56 [OpenVPN] WireGuard Client 8681: 946.50:Information: Start the program / Add a new interface
2020-04-26 08:00:57 [OpenVPN] WireGuard Client 8681: 946.75:Information: Assign an IP address and peer
2020-04-26 08:00:57 [OpenVPN] WireGuard Client 8681: 946.77:Information: Configure the interface
2020-04-26 08:00:57 [OpenVPN] WireGuard Client 8681: 946.78:Information: Set config file for wg0 interface
2020-04-26 08:00:57 [OpenVPN] WireGuard Client 8681: 946.84:Information: Activate the interface
2020-04-26 08:00:57 [OpenVPN] WireGuard Client 8681: 946.85:Information: Check that the wg0 interface is available
2020-04-26 08:00:57 [OpenVPN] WireGuard Client 8681: 946.87:Information: Overriding The Default Route
2020-04-26 08:00:57 [OpenVPN] WireGuard Client 8681: 946.89:Information: Delete the default route
2020-04-26 08:00:57 [OpenVPN] WireGuard Client 8681: 946.91:Information: Restart firewall to apply iptables rules for WireGuard client.
2020-04-26 08:00:57 [OpenVPN] WireGuard Client 8681: 946.95:Generating Rules...
Done!
2020-04-26 08:00:58 [OpenVPN] WireGuard Client 8681: 948.42:Starting Firewall...
Done!
2020-04-26 08:00:58 [OpenVPN] WireGuard Client 8681: 948.43:Information: Optimize network settings
2020-04-26 08:00:58 [OpenVPN] WireGuard Client 8681: 948.44:Information: Show processes
2020-04-26 08:00:58 [OpenVPN] WireGuard Client 8681: 948.47: 8454 root 1080 S /bin/sh /www/cgi-bin/kamoj.sh addon_wg_client=kamoj&raw_reply=1&wg_client_enable=1
8682 root 1048 S /bin/sh /www/cgi-bin/kamoj.sh addon_wg_client=kamoj&raw_reply=1&wg_client_enable=1
24816 root 3136 S < wireguard-go wg0
2020-04-26 08:00:58 [OpenVPN] WireGuard Client 8681: 948.48:Information: Show Wireguard status
2020-04-26 08:00:58 [OpenVPN] WireGuard Client 8681: 948.49:interface: wg0
public key: BlE79tZ6+KVJsxGKcojIm0vLDZm9XRPigb1lfSuCp0g=
private key: (hidden)
listening port: 57215
peer: hA8R55jbCj2EhbAAXEaRKFqsnjpixUwKauFUTBCBeC4=
endpoint: 2.49.147.209:51820
allowed ips: 0.0.0.0/0
transfer: 0 B received, 148 B sent
2020-04-26 08:00:58 [OpenVPN] WireGuard Client 8681: 948.50:Information: ip route after starting wireguard
2020-04-26 08:00:58 [OpenVPN] WireGuard Client 8681: 948.52:0.0.0.0/1 dev wg0 scope link
2.49.147.209 via 172.16.10.217 dev ppp0
10.0.0.0/24 dev wg0 proto kernel scope link src 10.0.0.3
128.0.0.0/1 dev wg0 scope link
2020-04-26 08:00:58 [OpenVPN] WireGuard Client 8681: 948.53:Information: Show ping time and to see if DNS is working
2020-04-26 08:01:28 [OpenVPN] WireGuard Client 8681: 978.57:
2020-04-26 08:01:28 [OpenVPN] WireGuard Client 8681: 978.58:Information: Wireguard Client completed start sequence
2020-04-26 08:01:28 [OpenVPN] WireGuard Client 8681: 978.59:=============================================================
