I currently have time restrictions setup on my wifi router. If i install a wireless AP will the AP just extend my range and not effect my current time restrictions/router settings, or will I need to also config the AP for the same time restrictions my router uses?
Thanks for the help. I forgot to mention that only the wifi shuts down for certain hours and yes i am using mac filtering for the devices that are affected by the hours restriction. so i guess since mac filtering is in place, then i should just be able to install the AP with minimal config.
by the way, i have never installed an AP. will i have some config work to do like set default gateway or are AP's pretty much plu and play?
Welcome To SNBForums
