I have two buildings, in which I need to connect to each other. I've been trying to figure out what would be the best method to approach this. The two buildings are around 1.45miles from each other (taken from the longitude/latitude) on google, straight pathway. I was wondering if you guys can provide some input on how I would go about this.
1. The main location is really close to a small airport (maybe 1/2 mile south). The second location is northwest from the main building, so it's the opposite direction of the airport)
2. I'm trying to connect both buildings via wireless with at least 10 to 20 mbit in bandwidth. I was thinking of the Engenius EOR7550 as a possibility.
3. How can I determine if LOS or nLOS would be possible? Can I do the site survey myself and should I get a professional do come by to look at it and evaluate it? I don't think I can see the other building from the roof at the main location.
4. If LOS/nLOS is there, would I need any permits and such if I erect an antenna for a setup like this using the standard 2.4GHz or 5.8GHz bands, if I really need to get the antenna high up to be able to connect to each other?
