L
Lo¨k
Guest
Hello all,
When there is more than 400KB/s being downloaded from the internet by a wireless client the DIR-825 says "2.4GHz Band: Wireless restart" and all the wireless clients get disconnected. I have also tried the Linksys WRT110
and the Dlink WBR-2310, they also drop on heavy load.
My question is, is it a problem with my setup or a problem with the wireless AP? If so, is there a good wireless AP that can handle in the 800KB/s of down traffic? (I'm ready to pay in the 250$+ if need be).
More details: I can reproduce a crash with only one wireless client, however most of the time there are 3 clients (max 4). Downloading a big file 1.1gig from a wireless client to another (Vista Sp1 -> WinXP pro sp2) was going at 1.1MB/s without causing the problem (the transfer was internal).
Here is my setup
cable modem -> smoothwall (old IBM box 2.66ghz w/ 756mb of RAM) -> Dlink DIR-825's gigabit switch -> 2 computers + VoIP adapter (dlink VTA)
I run the DIR-825 in AP mode (no dhcp, no QoS, no nothing) and the box running smoothwall handles everything (DHCP, QoS, Port forwarding). The problem occurs with both firmware 1.00 and 1.01.
The Wireless AP operates in the 2.4ghz band only (for testing purpose at this point) with WPA-Personal TKIP, the Group Key Update Interval is set to 3600 seconds.
I have try setting the MTU of all wireless NIC to 1300 and it did not fix the problem.
I really don't know what to do/how to troubleshoot this problem. I don't think it's interference since internal transfer works well, the strengh of the wireless network is good everywhere... I can only think of wireless AP failure but I tried 3 and they all had similar problems.
Thanks for reading.
Here is my setup
Thanks for reading.
