Hey all,
Hoping to get some answers to a couple of quick questions about my current wireless setup that have been bugging me for a while now. Love this site and hoping you'll be able to help me with my problems.
I currently run a wireless N network from a Linksys WAG160N router that unfortunatly has to sit right next to the master phone socket in the house to get any DSL. I have been connecting to this at the very limits of its range using a Linksys WUSB300N wireless adapter.
This setup is ok, but due to the extreme long range and various walls/windows my signal quality is pretty poor and bad weather can really affect if I get internet or not.
I recently invested in some Homeplug AV's (the Linksys PLK300 kit), but unfortunately I lose signal between these if they are plugged in, 1 near the router and the other next to my desktop.
However, I have found a socket closer to my desktop which does get signal through the Homeplugs, so what I have currently done is run the internet through the homeplugs to this point, from the homeplug to an old Linksys WAG300N that I had lying around and used this as a wireless AP to re-broadcast the signal for my desktop to recieve.
So, my 1st question is, if I bought another homeplug kit could I run a 2nd homeplug network from this 'middle' point over to my desktop. Doing away with the need for the WAG300N set in AP mode? In effect making my desktop have a wired connection to my router (abit through 2 homeplug AV networks and losing loads of quality and speed, but I have a bad internet DSL line anyway so I don't get good internet anyway).
My 2nd question is more of a troubleshooting thing. If I connect to my WAG300N it can see the internet in its AP mode re-broadcasting the signal from the WAG160N. However it seems to have a reasonably regular 'lag spike'. It will load up pages and download files at a resonable speed for 20-30 seconds and then have around 10 seconds where it almost seems to lose internet, before starting to work fine again for another 20-30 seconds. Do you have any idea what could cause this and how it could be fixed?
Thanks in advance,
Karde
Thanks in advance,
Karde
