Greetings:
I live in a single story home which was built in the early 1950. The exterior walls are framed with 2x wood studs, clad with lath and finished with stucco siding. Interior finishes consists of lath and plaster & drywall in select locations. The structure has been added onto twice, both times in the late 1950’s using similar construction practices. I have an exterior garage, with a 20ft x 20ft footprint, of original construction, located approximately 5 feet from an exterior wall of one of the additions (see attached plan view of residence and location of each AP).
Background:
I’m utilizing a wireless router/ access point to provide internet access inside of my house. It works reasonably well and coverage is fairly consistent throughout all of the original rooms and two additions. Wireless coverage outside of my house, in the backyard, the front yard and detached garage is dismal.
To address these gaps in coverage, I’ve tried the following solutions with varying success.
My dilemma:
The wireless signal inside of the garage appears to be high quality, but when testing the actual speed via speedtest or attempting to download a large file through this connection, I have inconsistent results. Depending on where I am standing within the garage, the signal quality varies significantly.
Questions:
Thanks in advance for your advice and insight.
Background:
- To address the gap in coverage in the front yard, I installed a TL-WR1043ND in the front closet which is resting against an exterior wall. I’ve ran Category 5 networking cable (Cat5e, I believe) from the RT-AC68U to the front closet. I disabled DHCP on the TL-WR1043ND and configured the wireless to run on a different 2.4 GHz channel than the one being used on the RT-AC68U. Despite the exterior wall, this configuration reliably provides wireless access to the front yard. I consider this a success.
- To address the gap in coverage in the garage and back yard, I needed to determine how to run cable between the house and the garage in an unobtrusive manor (not draping it from the roof or other ridiculous ideas). Initially, I installed a TP-Link Powerline Network to provide connectivity to a DIR-655 wireless router placed in the detached garage. This connection proved spotty and inconsistent, particularly when large AC motors where running (see washing machine, AC compressor).
- I removed the Powerline Network and ran a 200’ Category 5 networking cable (Cat5e) along the top of the fence which boarders my property and in through the rear of the garage to the DIR-655. I placed the DIR-655 right above the top of the roll up aluminum garage door on the interior face of the 4x header. I’ve tested the quality of the DIR-655 wired connection via LAN Speed Test and it is gigabit. (see attached picture for location of DIR-655)
My dilemma:
Questions:
- How does the router placement in immediate proximity to the garage door impact the quality of the wireless signal?
- Would moving the router a rafter above the garage door, away from the 1950’s walls and aluminum garage door improve signal quality?
- How does the orientation of the three antennas impact the signal quality?
- I’ve modified the DIR-655 router to improve airflow and reduce heat using the following DIY method: http://www.markalway.com/dlink_router/
- Might the proximity of the fan motor inside the router casing have a negative impact of the wireless signal quality of the DIR-655?
- Could replacing the DIR-655 with a new unit, say the TL-WR1043ND solve my problems, without any further configuration changes?
