To take full advantage of your dual-band N router, does your N adapter need to be 5 GHz capable?
I need a PCI (not USB) N adapter and I have only been able to find one that is 2.4 GHz & 5 GHz capable: Cisco's WMP600N (which seems to be discontinuing). For example, if you look at the specs for TRENDnet 300Mbps Wireless N PCI Adapter TEW-623PI, the Wireless Frequency Range: 2.4 - 2.4835 GHz only.
Thank you for your help in advance!
