Hello guys and gals. I'm new to this forum. Please bare with me.
I have a netgear WNDR3400 set up as my main router at a church building and we need have the majority of the building covered with WiFi signal. I have been reading for some time now and came to conclusion that we should get a couple (5-8) WN2500RP repeaters to grab signal at 5ghz band and extends the signal with the 2.4 ghz band. I chose this router because it has the 2 bands so my transfer speeds won't be cut in half as an article here stated and because we can use wpa2.
My main concern is being able to get as much of the 15mbps/3mbps speeds provided by isp in most places we throughout the church. We won't be transferring files so the throughput speeds are not that important. Do you think that set up will work? What other repeaters would you recommend? All we want to do is extend one signal everywhere and maintain speed constancy. The church is 4 stories. its somewhat large.
Thank you for the time and patience.
Sent from my X909 using Tapatalk 2
