WOL w Asuswrt Merlin
paulb787
Hey,
I have been trying to get WOL working and just havnt been able to do so on stock or merlin but dd-wrt no problem. I believe it has something to do with needing a static arp. It will work sometimes but not all.
DD-WRT uses arp -i br0 -s 192.168.1.254 FF:FF:FF:FF:FF:FF in the commands. It says not to change the mac and just use FF:FF:FF:FF:FF:FF..
would there be a way to set this up in asuswrt merlin. I prefer that firmware over dd-wrt.
Hey,
I'm actually using the same arp command together with port forward and WOL works fine even from Internet.
should I use arp -I br0 -s 192.168.1.111 FF:FF:FF:FF:FF:FF
OR arp -I br0 -s 192.168.1.1111 My:ACTUAL:MAC
or
I have seen
arp -s 192.168.1.1111 My:ACTUAL:MAC
and where should I put it? in services-start script?
or
I have seen
You should always use FF:FF:FF:FF:FF:FF in arp command. You only use the real MAC address in WOL client.
I guess service-start is fine. But I also add a cru command in that script to create a cron job to refresh that arp command every hour. Otherwise it'll be removed sooner or later.
Sent from my Xperia ZR using Tapatalk
EDIT: I checked and found that my arp command is added in wan-start while the cron command in init-start.
