The reason I'm asking for confirmation is because Linksys is investigating the issue of random reboots occurring at my request and others in our team. In this and other posts users were posting that this was occurring regularly.
Since I posted in this post and other forum threads of the WRT1900AC resetting the LAN\WLAN on configuration changes was by design. I'm finding that complaints of random reboots has all but disappeared.
Instead they seem to have shifted to more 2.4ghz wireless disconnect issues.
I could be missing how the situation has change but I hope not.
Okay, my reboots happened when the router was just sitting there, and were not 2.4GHz. band drops. Guess I'll have to get it out again and see what happens, then. I haven't changed any settings on it for some time, but I do bring up the status page occasionally to see what the uptime is. I did disable IPv6 for testing purposes, that's about it.
I assume that just looking at the status isn't what's supposed to be triggering reboots then, you actually have to change a setting in the GUI?
That's an odd design by the way. Most routers just restart the affected piece if you change a setting, not do a full reboot when settings are changed. Like if you change the wireless settings, they will restart the radios with the new parameters. Not do a full reboot. If you do a full reboot, that would take out the wired connections as well as the wireless, that doesn't make much sense to me.
A full reboot, although it shouldn't be necessary for just changing a setting most times, will certainly cause the new settings to be picked up. I guess you need to clear the decks on this router before changing any settings, make sure nothing important is happening, warn all the users, since a router reboot should be expected. Odd.
