x3mRouting x3mRouting Update (30 December 2020)
Xentrk
Part of the Furniture
x3mRouting (30 December 2020) updates include:
1. x3mMenu - updated firmware version check to include 386.x releases
2. x3mRouting.sh Script - revised code that prevents multiple versions of x3mRouting from running at the same time and how the jobs are queued. Fixes issue that may prevent a job from running at system boot or results in an empty IPSET list being created.
Update x3mMenu
Select option 7 to update the menu.
Update x3mRouting.sh Script
After updating the x3mMenu, selection option [5] Check for updates to existing x3mRouting installation
I pushed another update to x3mMenu for the check firmware version function. No version number change. Option [7] Update x3mRouting Menu will automatically be displayed if the check sum of the local file is different from the one posted on GitHub.
