Xbox and Asus routers, unbearable lag
doc octopus
Router: GT-BE98, last firmware
PPPOE connection via VDSL2 modem
Use for online game on Xbox Live
I point out an unbearable latency, they are aware that adaptive qos does not work, but also with traditional Qos or off the games are unjustable. I tried to disconnect all the devices and leave only the Xbox connected but without result.
The problem was also present on previous routers, mitigated only by the use of Flexqos. But is it possible that without the use of a "mod" there is an unsolved problem for years?
Do you have the modem/router (Draytek Vigor 167) in bridge mode?
I don't experience this at all with my PPPoE fiber connection and Ethernet connected RT68U or AX86U Pro without any QOS
Not sure the issue, but having used the N66U, AC68U, and still using the AC86U with Virgin Media and Sky broadband over the years, I've never had any performance issues with Xbox or PlayStation online when wired or wireless, other than the usual odd high ping and lag you get on faraway servers.
DSL can be a problem even with the wonky Asus QOS. When I was on DSL doing a speed, or bandwidth, test then setting the QOS to manual with the settings at 90 % of the test results seemed to help. If your DSL speeds vary, go lower on the settings.
Edit: Maybe a WIFI 7 router was not a good choice...
There's no Asus-specific reason for you to be experiencing this problem, especially as other people don't have this issue. So I suggest you try lowering the MTU value and see if that fixes the problem. If it doesn't then I'd say this is an ISP related problem.
Yes, same problem with another dsl modem, the zyxel vmg4005
Your DrayTek Vigor167 device is a modem/router. Do you have the same issues when your Xbox is connected directly to DrayTek device in gateway/router mode? Yes - it's your Internet connection. No - it's your device connected after DrayTek.
Ah, good catch! DSL/PPPoE MTU recommended @ 1492.
Did the suggestions mentioned here fixed your issue? It could be an ISP issue as mentioned here if you remove the Asus router and issues still persist with the Draytek Vigor combo in-place.
Not long before I posted in this thread, I had set up my AC86U in place of a Sky Hub at my partner's house to improve network performance with the multiple devices in use, particular since there's a PS5 and Xbox One there and I've taken my Series X and S over and the Sky Hub was clearly not happy.
The hub / router placement is in the kitchen at the rear of the house and my console couldn't be further away, upstairs on the opposite side of the house. Even with a weak to moderate 5 GHz signal and with the other two consoles in use, both my Series consoles perform great in multiplayer, despite the less than optimal wireless setup.
I've always been impressed with how the AC86U performs and hope the AX86U does at least a good a job if I finally get one to use in its place.
