This thread must live until there is justice!
360 downloading while connected to AirPort Express:
What your looking at here with the AirPort Express is the link speed while connected to N is 11Mbps limiting downloads to about 800KB/s. Yet when forced to B/G the link speed is 54Mbps letting the download go much quicker (1.5MB/s).
- 2012 AirPort Express N Only: Rate Graph | Speed Graph
- 2012 AirPort Express B/G: Rate Graph | Speed Graph
In comparison the RT-N66U link speed while connected to N only manages 5.5Mbps and about 400KB/s. And with the RT-N66U set to G it manages a 54Mbps link and about 2MB/s downloads.
..The next question is will the NAT be open for both consoles or will I have to use port forwarding, dmz, etc.
You could manually open the ports or DMZ the entire 360 but why? The 360 uses UPnP to automatically open ports. All you have to do is find the "Enable UPnP" option in the routers settings, check it and your done.
Not accounting for flaws in UPnP, I trust every device on my LAN. Not only that every but PC I have runs its own secondary firewall.
If there is a device that has malware on my network I've got more problems that some open ports.
I'm not saying your wrong, I'm just saying if your careful you'll be fine (provided you don't have one of the firmware's with UPnP flaws).
Anyone have an xbox 360 slim connected via the internal wireless card? For some reason mine only gets 11Mbps.
..I have a DLINK DIR-827 capable of 300Mbps on both the 2.4 and 5 Ghz spectrum. It reports actual Mbps connection rate and signal strength through it's browser interface. It shows 11 Mbps and 96% on the 2.4 Ghz band for the xbox internal card...
..I've tried open security, changing channels and moving the xbox 2 feet away from the router...
Source: Slomar | http://forums.dlink.com/index.php?topic=50107.0
>_< The anticipation is killing me and it has only been 30 seconds. This is gonna be rough.
Maybe you should sweet talk him into getting it to Merlin early so we can you know... beta test![]()
In the Wireless tab they've added a new check box called "optimize xbox" right next to "b/g protection".
Welcome To SNBForums
