YazDHCP YazDHCP - feature expansion of DHCP assignments (increasing limit on the number of DHCP reservations)
Correct, no ssh. It's the greatest reason there is for having this addon. Export, reinstall, import (after making any necessary changes to the LAN IP (must match)).
If you've added custom icons you can backup and restore those too, but that process involves copying a file off the router then adding it back after reinstall. I don't bother doing that, I have all my icons on the laptop.
Ok good.
What do you mean by "after making any necessary changes to the LAN IP" ?
For icons, I'm using the ones integrated.
Thanks for all your help 🙏🏻
If you're choosing to use anything other than the LAN's default IP. If you did change it you'd know what I was referring to so no worries there.
Ok you mean like mine is 192.168.31.xxx, I should put all that before importing ?
@Jack Yaz just here to say happy new year and thank you for this addon. Switch and router crapped out the last week and I had to go through and manually reenter a ton of reservations. Now using this tool and realizing just how darn easy it makes things going forward!
For IPv6. I have it disabled in its tab. But I also have YazDHCP 1.0.6 installed. Someone, maybe YazDHCP, is still handing out an IP address to my Pixel8a phone when presented with an IPv6 MAC address. How do I disable IPv6 DHCP in all places? I suspect my phone will default to its IPv4 address if IPv6 fails.
There’s no such thing as an IPv6 MAC address. What are you really seeing? An IPv6 link local address on the phone? That’s locally generated. YazDHCP doesn’t do IPv6.
That is not what YazDHCP does.
PS: Are you sure your phone isn't configuring an IPv6 address for itself? My Android phone assigns itself an IPv6 address even though IPv6 has been disabled in the router firmware from the start both on Asus-Merlin + YazDHCP and on stock Asus 3006.102.x firmware.
I noticed some strange behavior recently (couple of months), but I am not entirely sure if it's YazDHCP related. I have 88 DHCP reservations using YazDHCP at the moment if that matters (half of that I should probably clean up one of these days).
When I change device names and change icons, it doesn't always stick. Sometimes it does, sometime it doesn't. I had this for a long time, but I'd like to find out why I have this problem.
Example:
This is how it shows up in the DHCP page (this is not a new entry, it's been there for a couple of reboots actually):
Points to note: Default icon, New device
When I click on the icon, it looks like this (so it actually seems to know I have a custom icon):
Point to note: It knows I changed the icon
When I actually change the name above and hit apply, it just doesn't take (it stays "New device').
There is no error, not on screen, not in the log.
Some entries I can update without problem. That's the strange thing.
Any ideas how to debug this or where to look for pointers?
I believe I had this behavior for a while, a few FW versions at least.
I just removed 20 old DHCP reservations, same problem even after reboot.
I also just tried Chrome instead of Firefox, still the same.
Apologies for the large screenshots, I have no idea why there are so big when I post them here (it's not the actual size on my screen).
RT-AX86U Pro / 3004.388.8_4
YazDHCP 1.0.6
I have a couple of user icons, but not really using them extensively as far as I can tell.
meep@AX86U-KRN:/tmp/home/root# ls -la /jffs/usericon
drwxr-xr-x    2 meep   root          2336 Jan  8 07:54 .
drwxr-xr-x   15 meep   root          2128 Jan  9 14:33 ..
-rw-rw-rw-    1 meep   root          2298 Oct 12 07:39 0011327111E5.log
-rw-rw-rw-    1 meep   root           586 Dec  3  2022 1.log
-rw-rw-rw-    1 meep   root           998 Oct 21 18:17 135.log
-rw-rw-rw-    1 meep   root           558 Oct 12 07:37 18.log
-rw-rw-rw-    1 meep   root           686 Dec 30 17:47 22.log
-rw-rw-rw-    1 meep   root           682 Jul 15  2023 23.log
-rw-rw-rw-    1 meep   root         12907 Dec  4  2021 244BFEE4A0D0.log
-rw-rw-rw-    1 meep   root          9662 May  5  2018 244bfee4a0d0.ico
-rw-rw-rw-    1 meep   root           606 Nov  9 08:00 26.log
-rw-rw-rw-    1 meep   root           602 Jul 26  2022 27.log
-rw-rw-rw-    1 meep   root             0 Apr  1  2024 30f7726e62bd.ico
-rw-rw-rw-    1 meep   root           462 Jul  6  2024 35.log
-rw-rw-rw-    1 meep   root           618 Dec 10 20:57 4.log
-rw-rw-rw-    1 meep   root           490 Dec 28 07:27 40.log
-rw-rw-rw-    1 meep   root           682 Jan  8 07:54 46.log
-rw-rw-rw-    1 meep   root           786 Jul 26  2022 5.log
-rw-rw-rw-    1 meep   root           902 Dec  4  2021 60.log
-rw-rw-rw-    1 meep   root           658 Jul 25  2022 68.log
-rw-rw-rw-    1 meep   root           758 Oct 27  2023 70.log
-rw-rw-rw-    1 meep   root             0 Jun 20  2022 705a0f0d675e.ico
-rw-rw-rw-    1 meep   root           666 Dec 27 09:19 72.log
-rw-rw-rw-    1 meep   root           438 Jun 23  2022 78.log
-rw-rw-rw-    1 meep   root           686 Oct 12 07:36 81.log
-rw-rw-rw-    1 meep   root           974 Jul  4  2024 86.log
-rw-rw-rw-    1 meep   root          2298 Jun  1  2024 9009D0546996.log
-rw-rw-rw-    1 meep   root          3574 Oct 11  2021 B827EB84829D.log
-rw-rw-rw-    1 meep   root          4826 Jul  4  2022 B827EB8AE5CD.log
-rw-rw-rw-    1 meep   root          3574 Oct 11  2021 B827EBD19602.log
-rw-rw-rw-    1 meep   root          4890 Nov 24  2022 E45F01E54D85.log
-rw-rw-rw-    1 meep   root          4890 Nov 24  2022 E45F01E54D86.log
-rw-r--r--    1 meep   root           401 May  5  2018 usericon_md5.json
Right, I got that wrong. I was referring to a 64-bit MAC address, and confused a long MAC addr with a IPv6 addr.
Example:
[/code]
I had a similar issue awhile back. First you can try unplugging the router & modem for 10-15 minutes. If this doesn't work the only thing the worked for me was to reset my router and setup form scratch. Do not restore from a previous setup. After resetting router it allowed me to change names & icons again. I'm thinking something unexpectedly went haywire along the way.
It used to be the case that "New Device" would appear under Client Name even after entering a custom name, until the first time that device connected to the network.
How do we get YazDHCP 1.07 (develop version) turned into the release version?
It's been this way for months now.
We sit and wait, whilst giving the occasional nudge (as you just have 😉)
The original developer (@Jack Yaz) is no longer actively developing their scripts. Hopefully they'll promote the develop version to release version at some point when they have a free moment and or when they feel its warranted.
