YazFi YazFi - enhanced AsusWRT-Merlin Guest WiFi inc. SSID <-> VPN Client
I don't have ipv6 enabled.
Interesting results when I temporarily disable Skynet.
1) Ping from main wireless (10.100.100.x) to guest (10.100.2.x) > failed (this passed before)
2) Ping from main wired (10.100.100.x) to guest (10.100.2.x) > failed (this is unchanged)
3) Ping from guest (10.100.2.x) to guest (10.100.2.x) > pass (this is unchanged)
edit: not sure if this info will help but here goes anyway:
Guest network: all devices get IP through DHCP
Main network: all existing devices have a static ip, DHCP enabled for new devices (none connected that don't have static IP as of now)
I think I have got this fixed in the develop branch, I will PM you with a link to a patched script.
Essentially the issue is that I was only blocking new connections - any related/established could pass through. While this seemed fine in 99% of my testing, I found that in some situations connections would be allowed. YazFi will now block connections regardless of state, and I have moved the YazFi chain insertion as below:
From
-A FORWARD -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -j YazFiFORWARD
to
EDIT: This addresses points 1 and 2, 3 I have a fix I'm trying locally before pushing to the script
Confirmed the change fixes 1 and 2! Many thanks :)
YazFi v2.3.9 has been released
Changelog:
Update YazFi to fix isolation of guest from other networks
YazFi now blocks regardless of connection state
To update:
/jffs/scripts/YazFi update
Many thanks to @infra_red_dude for helping me track down the issue - I recall a user previously had a similar issue, but at the time, I could not re-create it
Hello!
I have Asus AC66U and i want that users from guest network were able to connect to local dns (pihole).
Here is config:
wl01_ENABLED=true
wl01_IPADDR=172.18.0.0
wl01_DHCPSTART=160
wl01_DHCPEND=199
wl01_DNS1=172.16.0.2
wl01_DNS2=172.16.0.2
wl01_FORCEDNS=true
wl01_REDIRECTALLTOVPN=false
wl01_VPNCLIENTNUMBER=
wl01_LANACCESS=
wl01_CLIENTISOLATION=
Does this feature work in YazFi v2.3.9?
Hello!
Here is config:
wl01_ENABLED=true
wl01_DHCPSTART=160
wl01_DHCPEND=199
wl01_FORCEDNS=true
wl01_LANACCESS=
It should indeed! Let me know if you run into any issues
What does
iptables -S YazFiFORWARD
look like?
iptables v1.3.8: Unknown arg `-S'
iptables -L YazFiFORWARD
Chain YazFiFORWARD (1 references)
target     prot opt source               destination
YazFiREJECT  all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere
Ah, which firmware version are you running?
I'm getting ready to unveil YazFi v3.0.0 which moves to a menu system (commands are still supported!) - ready for integration with amtm
Are there any willing testers out there?
I'd much rather be doing that than doing what I am doing this weekend, which is going to the funeral of a very good friend taken way too early by metastatic breast cancer. :-( I'm planning on being far too drunk to be of much use testing.
Sorry to hear that - all the best, and while tempting, don't drink too much
/me raises hand up to be guinea pig :D
I can surely help test the use cases that I currently use YazFi for (guest isolation, separate subnet etc., no VPN though).
Hey Jack,
I finally managed to acquire a testing device an 68U apart from my normal network setup, I can give it a whirl.
Obviously it will not be on my 5300 due to my network setup, so I can't try the extra radios. :(
Jack Yaz,
I am running an RT-AC3100 as the main router and an RT-AC68U as an AP.
I'm not sure if your script can support this setup? If it does; great!
If it doesn't; I'm willing to drop the RT-AC68U to test your v3.0 script out. Having it be 'amtm' compliant is a huge boost in usabilty. I've just recently started using amtm and I know I'm lost without it.
If you want feedback from a newbie, I'll do my best to help.
