TheUntouchable
No suprise, stalked his gitNice surprise, Jack. Works great, thanks!
You may need to give it a minute or two to put files (and services) in place.![]()
I got the following error even after upgrading lot of times with uf when I choose option 1:
mount: mounting /tmp/index_style.css on /www/index_style.css failed: No such file or directory
Anything I did wrong?![]()
Your 'first post' that I see above is you stalked the git.
Then you said:
Which is why I asked if you tried it with 'u' first.
I hope the re-install helps. Saving a configuration isn't necessary here is it? Just a few simple settings to recreate.![]()
I'm assuming that there are no other updates to any of the other scripts installed. And that you have a 1GB swap file or larger.
Maybe it's time to try a reboot? Before you do, uninstall YazFi completely to test this fully.
@Brenneke are you just updating your status or stating there was an update to YazFi?
I don't see a YazFi update though...
Did just waiting a few minutes help?
Welcome To SNBForums
