I haven't tried, but is it possible to set up a 2.5 & 5 with the same SSID and use Smart Connect so that I could give guests 1 SSID and 1 password to setup their device? Or would this break something
RebootIs there a quick way to remedy this? It doesn't seem to cause a problem, but it is aesthetically displeasing![]()
Reboot
@zshell98 Check the latest post from Jack. He is looking for more testers. I did already and it's working for me. ThanksHI, are you able to work it out? I have the same issue and looking for a solution.
Mar 12 15:35:34 rc_service: httpds 1058:notify_rc start_yazfi
Mar 12 15:35:34 custom_script: Running /jffs/scripts/service-event (args: start yazfi)
Mar 12 15:35:34 YazFi: Updated settings from WebUI found, merging into /jffs/addons/YazFi.d/config
Mar 12 15:35:35 YazFi: Merge of updated settings from WebUI completed successfully
Mar 12 15:35:35 YazFi: WebUI config updated - running YazFi
Mar 12 15:35:35 YazFi: YazFi v4.0.1 starting up
Mar 12 15:35:35 YazFi: No YazFi guests are enabled in the configuration file!
Can you share a screenshot of what your rules looked like prior to disabling the guests?1. I had two guest networks enabled to a VPN. When I disabled them, the routing rules stayed in the VPN client. 2. I also made a rule after the rules when multiple guest networks were entered in to the VPN client. When I disabled a few guest networks, the rule I entered was deleted. 3. This also happened when I disabled the last two guest networks.
I understand that manually deleting the VPN rules left over and rebooting will probably fix everything. I just wanted to let you know.Code:Mar 12 15:35:34 rc_service: httpds 1058:notify_rc start_yazfi Mar 12 15:35:34 custom_script: Running /jffs/scripts/service-event (args: start yazfi) Mar 12 15:35:34 YazFi: Updated settings from WebUI found, merging into /jffs/addons/YazFi.d/config Mar 12 15:35:35 YazFi: Merge of updated settings from WebUI completed successfully Mar 12 15:35:35 YazFi: WebUI config updated - running YazFi Mar 12 15:35:35 YazFi: YazFi v4.0.1 starting up Mar 12 15:35:35 YazFi: No YazFi guests are enabled in the configuration file!
That's solved the problem. Thanks.@TheLyppardMan I can't reproduce your issue on a fresh install, but I suspect it's some sort of race condition/slow writing of the page after the first time download. What happens if you open YazFi and use option u?
Mar 13 07:41:55 YazFi: YazFi v4.0.1 starting up
Mar 13 07:41:55 YazFi: No YazFi guests are enabled in the configuration file!
I think I've found the cause of the 404 on install - fix will be out along with Chromecast fixes shortlyAfter disabling in the GUI menu and rebooting, the web page would not show. This is what it said.
Code:Mar 13 07:41:55 YazFi: YazFi v4.0.1 starting up Mar 13 07:41:55 YazFi: No YazFi guests are enabled in the configuration file!
I uninstalled and reinstalled. After I reinstalled through amtm, the web page was there but got a 404 on click. I had to force an update and everything worked again.
Here's the screenshot.
Not sure if its a bug in the Asus firmware coding (that Merlin firmware is based on) where the information is being pulled from the NVRAM, but the Network Map listing of DHCP addresses doesn't properly poll the right Guest IP addresses when using scripts like the YazFi script. Rather it uses the IP address of the main IP address subnet network, if that device was ever connected to the main IP address subnet. Instead look at the System Log > DHCP Leases page which should show the correct IP addresses being assigned by the guest network(s).Hello I am still a noob to the Asus router as I just bought it a month ago and of course soon after I discovered amtm scripts. I started installing them one by one starting with Skynet, Diversion, Common and yesterday I started playing with YazFi.
snip for readability.
I made a post earlier in the thread detailing how to take things even further and manually assign IP addresses to the various guest devices. See this post ##640 or this post #944 for more information.
Welcome To SNBForums
