Joshuajackson
if i try to login to guest it wont connect and says unable to assign IP and internet is unavailable
I am now, because it looked interesting plus i like the features it has. The issues i have with the router i still had even when i never installed YazFi.@Joshuajackson so you're using YazFi scripts too? In your other thread, you didn't mention this?![]()
Does the VPN client definitely work?Got a weird issue, Redirect Clients to VPN gives the Guest network no internet access, ive seen someone having the same issue here on this forum he fixed it by forwarding Port but still same issue for me. Anybody got a clue what im doing wrong?
https://imgur.com/a/7LXePfB
I'm not sure I've never used VPN on router, but I did follow what other did and didn't workDoes the VPN client definitely work?
What does the VPN show for connection status?I'm not sure I've never used VPN on router, but I did follow what other did and didn't work
Sent from my SM-A505W using Tapatalk
well of course redirecting the guest to a non-configured/off VPN client isn't going to work...
Sorry for being dumb lol I never knew you had to do it. Do I have to use VPN in order to get client isolation working? Because whenever I enable client isolation I cant connect to guest network.well of course redirecting the guest to a non-configured/off VPN client isn't going to work...
No, client isolation is a wireless radio setting that stops WiFi clients on the same network from being able to talk to each other. Which router and F/w?Sorry for being dumb lol I never knew you had to do it. Do I have to use VPN in order to get client isolation working? Because whenever I enable client isolation I cant connect to guest network.
The postconf file should have been emptied so restarting avahi won't enable reflector
I'm not sure how PiHole resolves names, to be honest
Sometimes arp can be a bit slow to clear older entries. Does the Wireless Log in System Log report the correct IPs? Does the device itself report correctly?Would this also work with the router?
I am having a similar issue where the devices won't show on the client list in the web gui, and but in the terminal, some of them don't show up with the correct subnets. COLONIAL ONE is my 192.168.2X and there is a XX.1.96 device, which I haven't been able to ID.
I haven all the interfaces running through an activated VPN Client, which all the subnets correctly show up as. I do have one device, a laptop that I bypass the VPN and it goes through the WAN instead and it shows up as a 192.168.1.XX.
My router is a AX56U firmware is 384.18 alpha1 srry for late replyNo, client isolation is a wireless radio setting that stops WiFi clients on the same network from being able to talk to each other. Which router and F/w?
Now, if you don't use VLANs then whatever you are using (firewall? iptables command?) allows for creating isolated subnets. I can probably write a script that uses the same commands you issue when creating the guest networks in order to create isolated subnets by tenantI do/did want to add VLANs, but I only have an HND router (AC86U) which uses different utilities for VLANs, and no-one seems to have a definitive way of using them (yet).
Welcome To SNBForums
