Aug 27 23:47:49 RT-AX88U-8158 YazFi: Forcing YazFi Guest WiFi clients to reauthenticate
Aug 27 23:47:59 RT-AX88U-8158 networkmap: Error unlocking 7: 9 Bad file descriptor
Aug 27 23:47:59 RT-AX88U-8158 networkmap: Error unlocking 0: 9 Bad file descriptor
Aug 27 23:48:04 RT-AX88U-8158 YazFi: YazFi v4.1.4 completed successfully
anyone else getting this error? thx
Code:Aug 27 23:47:49 RT-AX88U-8158 YazFi: Forcing YazFi Guest WiFi clients to reauthenticate Aug 27 23:47:59 RT-AX88U-8158 networkmap: Error unlocking 7: 9 Bad file descriptor Aug 27 23:47:59 RT-AX88U-8158 networkmap: Error unlocking 0: 9 Bad file descriptor Aug 27 23:48:04 RT-AX88U-8158 YazFi: YazFi v4.1.4 completed successfully
Check that Redirect Internet traffic in the VPN client screen is set to policy rulesThis may be a silly question... I had one guest network using VPN working just fine before, but now I am having trouble.
I configured the VPN client service entry in the router WebUI.
If I turn it ON all traffic goes through it which is not what I intend to do.
If I leave it OFF and assign it to a Guest network, I am still using the local WAN.
I am using 384.18 and latest Yazfi.
So what am I missing here? I scanned and searched the thread but cannot find the clue, VPN is too short and Client doesn't bring useful hits.
Thanks!
View attachment 25853View attachment 25854
Can you run option d for diagnostics and PM me the passphrase and a link to the diagnostics? (if you don't have an upload service let me know and ill send you a dropbox request)Newb. HI everyone
Grabbed a Asus RT-AX3000 (same same as RT-AX-58U)
Loaded up latest merlin firmware, 384.19. Followed instructions to get YazFi up, v4.1.4
Have configured OpenVPN with 3x OVN files (NamecheapVPN) for Singapore, USA & Australia. (actually did all 5 but 3 active atm to get working)
Started up the 3x 5Ghz Guest networks. Named SSID per country with WPA2 access, assigned each to the corresponding VPN in YazFi setting... Guest 1,2,3 > VPN x,y,z etc. (see attachments)
But it doesn't work. When I connect each guest network it give the main routers DHCP address, not the alternate ones defined in YazFi.
I can manually do a routing rule per device but that locks it to one VPN, meaning no matter which wifi network I am on it uses that VPN... Or if I stop all VPN except one they all use that one...
HOW do I get the different subnet addresses to be assigned by yazfi on connection to each wifi network?
I have tried every setting, YazFi is definitely not acting as a DHCP server separate from the Asus router.
Thanks in advance
//PS I checked, applied and forced update using SSH too...
View attachment 25916View attachment 25917View attachment 25918
@egrep, did you reboot the router and the client devices afterward? Did you wait 10 minutes for the settings to be applied properly?
Here are some more basic troubleshooting tips to check.
Troubleshooting 101 Asus/RMerlin Routers 2020
Top 10 Simple Asus/RMerlin firmware powered Router Troubleshooting steps to try first: NOTE: Although this is for Asus/RMerlin-firmware powered routers, the steps below may be relevant to all routers, to get to a quick fix for common symptoms. Check that the router’s System Time is accurate on...www.snbforums.com
Thanks!!Can you run option d for diagnostics and PM me the passphrase and a link to the diagnostics? (if you don't have an upload service let me know and ill send you a dropbox request)
Hello,
Since updating to 4.1.1 I am seeing the following in my log:
Code:...... Jun 24 06:40:00 RT-AC5300 YazFi: firewall rules not detected during persistence check, re-applying rules Jun 24 06:40:00 RT-AC5300 YazFi: YazFi v4.1.1 starting up Jun 24 06:50:00 RT-AC5300 YazFi: firewall rules not detected during persistence check, re-applying rules Jun 24 06:50:00 RT-AC5300 YazFi: YazFi v4.1.1 starting up Jun 24 07:00:01 RT-AC5300 YazFi: firewall rules not detected during persistence check, re-applying rules Jun 24 07:00:01 RT-AC5300 YazFi: YazFi v4.1.1 starting up Jun 24 07:10:00 RT-AC5300 YazFi: firewall rules not detected during persistence check, re-applying rules Jun 24 07:10:00 RT-AC5300 YazFi: YazFi v4.1.1 starting up Jun 24 07:20:00 RT-AC5300 YazFi: firewall rules not detected during persistence check, re-applying rules ......
I've tried force updating - I'm not sure what else to try to fix it. Can you help?
Sep 4 09:00:03 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 09:10:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 09:10:02 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 09:20:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 09:20:02 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 09:20:07 RT-AC88U YazFi: Firewall restarted - sleeping 30s before running YazFi
Sep 4 09:20:38 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 09:30:10 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 09:30:10 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 09:31:50 RT-AC88U YazFi: Firewall restarted - sleeping 30s before running YazFi
Sep 4 09:32:20 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 09:40:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 09:40:02 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 09:50:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 09:50:02 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 10:00:03 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 10:00:03 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 10:10:01 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 10:10:01 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 10:20:01 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 10:20:01 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 10:30:01 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 10:30:01 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 10:40:01 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 10:40:01 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 10:50:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 10:50:02 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 11:00:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 11:00:02 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 11:10:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 11:10:02 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 11:20:01 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 11:20:01 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 11:30:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 11:30:02 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 11:40:01 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 11:40:02 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 4 11:50:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 4 11:50:02 RT-AC88U YazFi: YazFi v4.1.4 starting up
I'm not sure on what the best approach here is. If the interface is disabled, rather than hard exiting, I could update the config file for YazFi to disable the affected interface and continue?I just found some kind of bug.
When, let's say, wl02 is enabled on yazfi, but then I disable the guest Network itself, on yazfi config file the wl02 keeps the enabled=true var.
However, because of that, all other guest networks don't work properly - the rules aren't applied. (Ip range, DNS, etc).
However when I manually went to config file and set enabled=false on the wl02 which has been disabled on guest Network page also, the others started working.
are there any messages in between with something re-setting your firewall?Hi, I have the same problem, this same message keep showing up :
Code:Sep 4 09:00:03 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 09:10:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 09:10:02 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 09:20:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 09:20:02 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 09:20:07 RT-AC88U YazFi: Firewall restarted - sleeping 30s before running YazFi Sep 4 09:20:38 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 09:30:10 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 09:30:10 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 09:31:50 RT-AC88U YazFi: Firewall restarted - sleeping 30s before running YazFi Sep 4 09:32:20 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 09:40:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 09:40:02 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 09:50:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 09:50:02 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 10:00:03 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 10:00:03 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 10:10:01 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 10:10:01 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 10:20:01 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 10:20:01 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 10:30:01 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 10:30:01 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 10:40:01 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 10:40:01 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 10:50:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 10:50:02 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 11:00:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 11:00:02 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 11:10:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 11:10:02 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 11:20:01 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 11:20:01 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 11:30:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 11:30:02 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 11:40:01 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 11:40:02 RT-AC88U YazFi: YazFi v4.1.4 starting up Sep 4 11:50:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules Sep 4 11:50:02 RT-AC88U YazFi: YazFi v4.1.4 starting up
I tried Google and also search this forum, but couldn't find the answer. Can anyone help me?
Thanks a lot
That's the best way I think to do.I'm not sure on what the best approach here is. If the interface is disabled, rather than hard exiting, I could update the config file for YazFi to disable the affected interface and continue?
Sep 5 10:26:18 RT-AC88U custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Sep 5 10:26:18 RT-AC88U custom_script: Running /jffs/scripts/service-event-end (args: restart firewall)
Sep 5 10:26:19 RT-AC88U FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=387) called with 2 args: -start ppp0
Sep 5 10:26:20 RT-AC88U YazFi: Firewall restarted - sleeping 30s before running YazFi
Sep 5 10:26:21 RT-AC88U FlexQoS: Applying iptables static rules
Sep 5 10:26:21 RT-AC88U FlexQoS: Applying iptables custom rules
Sep 5 10:26:22 RT-AC88U FlexQoS: No TC modifications necessary
Sep 5 10:26:50 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 5 10:27:11 RT-AC88U rc_service: amas_lib 25164:notify_rc restart_firewall
Sep 5 10:27:11 RT-AC88U custom_script: Running /jffs/scripts/service-event (args: restart firewall)
Sep 5 10:27:37 RT-AC88U nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Sep 5 10:27:37 RT-AC88U custom_script: Running /jffs/scripts/nat-start
Sep 5 10:27:38 RT-AC88U custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Sep 5 10:27:38 RT-AC88U custom_script: Running /jffs/scripts/service-event-end (args: restart firewall)
Sep 5 10:27:39 RT-AC88U FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=10561) called with 2 args: -start ppp0
Sep 5 10:27:39 RT-AC88U YazFi: Firewall restarted - sleeping 30s before running YazFi
Sep 5 10:27:41 RT-AC88U FlexQoS: Applying iptables static rules
Sep 5 10:27:41 RT-AC88U FlexQoS: Applying iptables custom rules
Sep 5 10:27:42 RT-AC88U FlexQoS: No TC modifications necessary
Sep 5 10:28:10 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 5 10:29:41 RT-AC88U YazFi: Firewall restarted - sleeping 30s before running YazFi
Sep 5 10:29:52 RT-AC88U kernel: br0: received packet on eth1 with own address as source address
Sep 5 10:30:02 RT-AC88U YazFi: Lock file found (age: 21 seconds) - stopping to prevent duplicate runs
Sep 5 10:30:03 RT-AC88U (gen_ytadblock.sh): 17419 Number of yt adblocked domains: 1457
Sep 5 10:30:03 RT-AC88U ddns: Completed custom ddns update
Sep 5 10:30:11 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 5 10:30:21 RT-AC88U rc_service: amas_lib 11052:notify_rc restart_firewall
Sep 5 10:30:21 RT-AC88U custom_script: Running /jffs/scripts/service-event (args: restart firewall)
Sep 5 10:30:22 RT-AC88U nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Sep 5 10:30:22 RT-AC88U custom_script: Running /jffs/scripts/nat-start
Sep 5 10:30:23 RT-AC88U custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Sep 5 10:30:23 RT-AC88U custom_script: Running /jffs/scripts/service-event-end (args: restart firewall)
Sep 5 10:30:24 RT-AC88U FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=19048) called with 2 args: -start ppp0
Sep 5 10:30:26 RT-AC88U FlexQoS: Applying iptables static rules
Sep 5 10:30:26 RT-AC88U FlexQoS: Applying iptables custom rules
Sep 5 10:30:27 RT-AC88U FlexQoS: No TC modifications necessary
Sep 5 10:31:56 RT-AC88U rc_service: amas_lib 11052:notify_rc restart_firewall
Sep 5 10:31:56 RT-AC88U custom_script: Running /jffs/scripts/service-event (args: restart firewall)
Sep 5 10:31:58 RT-AC88U nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Sep 5 10:31:58 RT-AC88U custom_script: Running /jffs/scripts/nat-start
Sep 5 10:31:59 RT-AC88U custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Sep 5 10:31:59 RT-AC88U custom_script: Running /jffs/scripts/service-event-end (args: restart firewall)
Sep 5 10:31:59 RT-AC88U FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=30942) called with 2 args: -start ppp0
Sep 5 10:32:00 RT-AC88U YazFi: Firewall restarted - sleeping 30s before running YazFi
Sep 5 10:32:01 RT-AC88U FlexQoS: Applying iptables static rules
Sep 5 10:32:02 RT-AC88U FlexQoS: Applying iptables custom rules
Sep 5 10:32:02 RT-AC88U FlexQoS: No TC modifications necessary
Sep 5 10:32:30 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 5 10:33:28 RT-AC88U YazFi: Firewall restarted - sleeping 30s before running YazFi
Sep 5 10:33:58 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 5 10:34:44 RT-AC88U rc_service: amas_lib 3804:notify_rc restart_firewall
Sep 5 10:34:44 RT-AC88U custom_script: Running /jffs/scripts/service-event (args: restart firewall)
Sep 5 10:34:46 RT-AC88U nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Sep 5 10:34:46 RT-AC88U custom_script: Running /jffs/scripts/nat-start
Sep 5 10:34:47 RT-AC88U custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Sep 5 10:34:47 RT-AC88U custom_script: Running /jffs/scripts/service-event-end (args: restart firewall)
Sep 5 10:34:48 RT-AC88U FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=4003) called with 2 args: -start ppp0
Sep 5 10:34:50 RT-AC88U FlexQoS: Applying iptables static rules
Sep 5 10:34:50 RT-AC88U FlexQoS: Applying iptables custom rules
Sep 5 10:34:51 RT-AC88U FlexQoS: No TC modifications necessary
Sep 5 10:35:01 RT-AC88U (gen_ytadblock.sh): 5040 Number of yt adblocked domains: 1457
Sep 5 10:36:55 RT-AC88U rc_service: amas_lib 11052:notify_rc restart_firewall
Sep 5 10:36:55 RT-AC88U custom_script: Running /jffs/scripts/service-event (args: restart firewall)
Sep 5 10:36:57 RT-AC88U nat: apply nat rules (/tmp/nat_rules_ppp0_eth0)
Sep 5 10:36:57 RT-AC88U custom_script: Running /jffs/scripts/nat-start
Sep 5 10:36:57 RT-AC88U custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Sep 5 10:36:57 RT-AC88U custom_script: Running /jffs/scripts/service-event-end (args: restart firewall)
Sep 5 10:36:58 RT-AC88U FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=16461) called with 2 args: -start ppp0
Sep 5 10:36:59 RT-AC88U YazFi: Firewall restarted - sleeping 30s before running YazFi
Sep 5 10:37:00 RT-AC88U FlexQoS: Applying iptables static rules
Sep 5 10:37:00 RT-AC88U FlexQoS: Applying iptables custom rules
Sep 5 10:37:01 RT-AC88U FlexQoS: No TC modifications necessary
Sep 5 10:37:29 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 5 10:37:57 RT-AC88U YazFi: Firewall restarted - sleeping 30s before running YazFi
Sep 5 10:38:27 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 5 10:40:01 RT-AC88U (gen_ytadblock.sh): 22307 Number of yt adblocked domains: 1457
Sep 5 10:40:02 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 5 10:40:02 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 5 10:40:03 RT-AC88U ddns: Completed custom ddns update
Sep 5 10:45:00 RT-AC88U (gen_ytadblock.sh): 25894 Number of yt adblocked domains: 1457
Sep 5 10:50:00 RT-AC88U (gen_ytadblock.sh): 28111 Number of yt adblocked domains: 1457
Sep 5 10:50:01 RT-AC88U YazFi: firewall rules not detected during persistence check, re-applying rules
Sep 5 10:50:01 RT-AC88U YazFi: YazFi v4.1.4 starting up
Sep 5 10:50:03 RT-AC88U ddns: Completed custom ddns update
Welcome To SNBForums
