war59312
Install Failing on RT-AC88U with AsusWRT-Merlin 386.7_2
Even this not working:
A clue:
Update 1:
Router > Advanced Settings > Administration > Set "Enable JFFS custom scripts and configs" to "Yes" > Click "Apply" > Reboot
Helps if option is enabled
Should hint to the user on README.md\
Update 2:
I don't keep this router connected to internet via WAN. It's behind a pfsense firewall.
So I tried to just create the .sh file and it did create the new guest network YazFi tab when I try and access it I get:
The ssh install shows:
Update 3:
Got the tab working by manually creating the /jffs/addons/YazFi.d/YazFi_www.asp file and running "Check for updates".
/jffs/addons/shared-jy/shared-jy.tar.gz was also reported missing , Grabbed it from shared-jy/shared-jy.tar.gz at master · jackyaz/shared-jy (github.com)
When trying to edit config, option 3, I got:
chmod: /jffs/addons/YazFi.d/config: No such file or directory
dos2unix: can't open '/jffs/addons/YazFi.d/config': No such file or directory
So grabbed the example config and fixed it up.
Sweet, looking good now. Should disable the upgrade check if WAN disabled/not setup.
Shows up ugly when WAN disabled:
Update 4:
All seems installed correctly but sadly no internet when connect to wifi now, despite "Allow Internet access" set to "Yes". Does NOT seem to be DNS since cant even browse to https://1.1.1.1/ .
will@RT-AC88U-CDF8:~# /usr/sbin/curl -fsL --retry 3 "https://jackyaz.io/YazFi/master/install/YazFi.sh" -o /jffs/scripts/YazFi && chmod 0755 /jffs/scripts/YazFi && /jffs/scripts/YazFi install
-sh: /usr/sbin/curl: not found
will@RT-AC88U-CDF8:~# curl -fsL --retry 3 "https://jackyaz.io/YazFi/master/install/YazFi.sh" -o /jffs/scripts/YazFi && chmod 0755 /jffs/scripts/YazFi && /jffs/scripts/YazFi install
will@RT-AC88U-CDF8:~# YazFi
-sh: YazFi: not found
will@RT-AC88U-CDF8:~# /jffs/scripts/YazFi
-sh: /jffs/scripts/YazFi: not found
will@RT-AC88U-CDF8:~# cd /jffs/
will@RT-AC88U-CDF8:/jffs# ls
will@RT-AC88U-CDF8:/# cd jffs/
will@RT-AC88U-CDF8:/jffs# mkdir test
A clue:
will@RT-AC88U-CDF8:/# curl "https://jackyaz.io/YazFi/master/install/YazFi.sh" -o "/YazFi"
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
Warning: Failed to create the file /YazFi: Read-only file system
will@RT-AC88U-CDF8:/# curl --retry 3 "https://jackyaz.io/YazFi/master/install/YazFi.sh" -o /jffs/scripts/YazFi && chmod 0755 /jffs/scripts/YazFi && /jffs/scripts/YazFi install
Warning: Failed to create the file /jffs/scripts/YazFi: No such file or
Warning: directory
Update 1:
Update 2:
404 Not Found
File not found.
## __ __ ______ _ ##
## \ \ / / | ____|(_) ##
## \ \_/ /__ _ ____| |__ _ ##
## \ // _ ||_ /| __| | | ##
## | || (_| | / / | | | | ##
## |_| \__,_|/___||_| |_| ##
## v4.4.2 on RT-AC88U ##
## https://github.com/jackyaz/YazFi/ ##
Welcome to YazFi v4.4.2, a script by JackYaz
Checking your router meets the requirements for YazFi
tar: can't open '/jffs/addons/shared-jy/shared-jy.tar.gz': No such file or directory
New version of shared-jy.tar.gz downloaded
New version of YazFi_www.asp downloaded
Mounting WebUI tab for YazFi
cp: can't stat '/jffs/addons/YazFi.d/YazFi_www.asp': No such file or directory
Mounted YazFi WebUI page as user1.asp
You can access YazFi's configuration via the Guest Networks section of the WebUI
Alternatively, use YazFi's menu via amtm (if installed), with /jffs/scripts/YazFi or simply YazFi
Press enter to continue...
Update 3:
Version information v4.4.2 Updated version available: [1m[31m404
Update 4:
