ZebMcKayhan
For the time being I think you need to handle this manually.Is it possible that YazFi can accept a ip6 address for the DNS fields? I’m using a smart dns service and they support multiple profiles but only the default profile is available by ip4 address.
some inspiration:
@SomeWhereOverTheRainBow just posted a way to replicate ipv4 DNS filter to ipv6 ip6tables:
uiDivStats - uiDivStats 3.x
I am running fully updated Merlin 386.4 on an AX86U with Diversion and UIStats. I have an issue in that Blocked Domains on the Diversion Tab (correct) does not match Domains currently on blocklist (it is doubled for some odd reason) on UIDivStats Tab. How can I fix this? Diversion must be...
recently I tried to assign separate ipv6 subnets (and DNS) to YazFi clients but never managed to prevent clients from obtaining br0 ipv6 so I ended up moving the guest wifi's out of br0, this works ok for me, but there is probably other ways:
GitHub - ZebMcKayhan/WireguardManager: Manage/Install WireGuard on applicable ASUS routers
Manage/Install WireGuard on applicable ASUS routers - ZebMcKayhan/WireguardManager
