I have a set of AX XT8 routers that I typically have set up in AI Mesh with a third Asus router. The primary node is connected via Ethernet to an ET2251 (DOCSIS 3.1, provided by Charter/Spectrum) cable modem. All routers are updated to the latest firmware (3.0.0.4.386_49873 for the XT8 ones).
Recently (I am not certain of the date, but I would say since August), we have been having substantial issues with realtime network applications (Zoom, Meet, etc).The system log (see example below) shows that the WAN port disconnects and reconnects within around 4 seconds. This happens with annoying frequency, sometimes multiple times in a minute.
Things I have tried:
Has anyone else seen a similar issue, perhaps after updating to the latest firmware? I do have a support ticket in w/ Asus, but have not yet received guidance. Since I have the issue with multiple XT8s (and cables), I believe it to be a software issue. I'm happy to try out any configuration changes that might help. At the moment, all I have done since factory reset was set up WiFi and mesh; all other settings are defaults.
- Restarting all mesh nodes & the cable modem
- Factory resetting all mesh nodes
- Swapping out the primary node (one XT8 for the other to eliminate hardware issue with the one WAN port)
- Swapping ethernet cables that connect router to modem (tried three, all experience the issue)
Sep 8 10:49:21 WAN Connection: WAN(0) link up.
Sep 8 10:49:21 rc_service: wanduck 1607:notify_rc restart_wan_if 0
Sep 8 10:49:24 wan: finish adding multi routes
Sep 8 10:49:25 miniupnpd[25073]: shutting down MiniUPnPd
Sep 8 10:49:25 miniupnpd: it is advised to use network interface name instead of 192.168.50.1/255.255.255.0
Sep 8 10:49:25 ddns: update WWW.ASUS.COM update@asus.com, wan_unit 0
Sep 8 10:49:25 ddns: Clear ddns cache.
Sep 8 10:49:25 ddns: Start Inadyn(10).
Sep 8 10:49:25 inadyn[25414]: In-a-dyn version 2.8.1 -- Dynamic DNS update client.
Sep 8 10:49:25 miniupnpd[25402]: HTTP listening on port 49943
Sep 8 10:49:25 inadyn[25414]: Update forced for alias A8C2796A623D274C322769C5909FA1945.asuscomm.com, new IP# <ISP_ASSIGNED_IP>
Sep 8 10:49:25 miniupnpd[25402]: Listening for NAT-PMP/PCP traffic on port 5351
Sep 8 10:49:25 kernel: Archer TCP Pure ACK Enabled
Sep 8 10:49:25 dhcp client: bound <ISP_ASSIGNED_IP>/255.255.224.0 via <ISP_ASSIGNED_IP> for 81385 seconds.
Sep 8 10:49:25 inadyn[25414]: alias address=<<ISP_ASSIGNED_IP>>
Sep 8 10:49:25 inadyn[25414]: request<GET /ddns/update.jsp?hostname=A8C2796A623D274C322769C5909FA1945.asuscomm.com&myip=<ISP_ASSIGNED_IP>&model=RT-AX95Q&fw_ver=3.0.0.4.386_49873-g72159cc HTTP/1.0^M Authorization: Basic N0MxMEM5MDVGMzEwOjg0NzJDMzgzOTBGNTU2RUVFOTNBODIzMjk4MDUxMTE0^M Host: ns1.asuscomm.com^M User-Agent: inadyn/2.8.1 https://github.com/troglobit/inadyn/issues^M ^M >
Sep 8 10:49:26 inadyn[25414]: [response_update]HTTP/1.1 200 OK^M Date: Thu, 08 Sep 2022 14:49:26 GMT^M Server: Apache^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Sep 8 10:49:26 inadyn[25414]: Updating cache for A8C2796A623D274C322769C5909FA1945.asuscomm.com
Sep 8 10:49:26 ddns: ddns update ok
Sep 8 10:49:26 WAN Connection: WAN was restored.
Sep 8 10:49:30 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0002, new 0x0002^[[0m
Sep 8 10:49:46 kernel: eth0 (Int switch port: 1) (Logical Port: 1) (phyId: 1f) Link DOWN.
Sep 8 10:49:50 kernel: eth0: sysport_tm port shaper set to 2497500 kbps, 150000 mbs (phy speed 2500000 kbps)
Sep 8 10:49:50 kernel: eth0 (Int switch port: 1) (Logical Port: 1) (phyId: 1f) Link Up at 2500 mbps full duplex
Sep 8 10:49:50 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 6, current 0x0001, new 0x0001^[[0m
Sep 8 10:49:51 WAN Connection: WAN(0) link up.
