Release ASUS GT-AX6000 Firmware version 3.0.0.6.102_21514
New2This
New features for ASUSWRT 5.0
-Kids' Wi-Fi: Create a separate network specifically for children, complete with scheduled controls. This is suitable for children who use multiple network devices that have enabled the randomized MAC address function and are not easily recognized.
-VPN WiFi: Create a VPN network that connects to 3rd party VPN services or with ASUS site to site -VPN(https://www.asus.com/support/FAQ/1048281/) to encrypts your internet connection and hides your IP address to protect your online activities from being tracked or monitored.
-IoT WiFi : Create an 2.4G spearate network for IoT (Internet of Things) devices.
Guest WiFi: Create a guest network with a WiFi schedule and access rights to control when and how guests can use the network.
-VLAN, allow you to segment a network into smaller, virtual sub-networks, which can be used to isolate traffic, please refer to https://www.asus.com/support/FAQ/1049415/
-Multi-services WAN, create multiple profiles on a single WAN interface. (https://asus.com/support/FAQ/1050072)
-Port isolation and AP isolation to restrict device access to each other.
Bug Fixes and Enhancements
-NowTV profile has been added under new IPTV profiles.
-IPTV settings have been updated for better compatibility with Unifi Biz VoIP service.
-Fixed a GUI bug that occurred when adding port range rules in the Network Service Filter.
-Resolved an issue that caused hostname errors in the DDNS service.
Security Fixes
-Fixed several curl vulnerabilities including CVE-2023-28322, CVE-2023-28321, and CVE-2023-28319.
-Fixed FFmpeg vulnerabilities, specifically CVE-2022-3964, CVE-2022-48434, and CVE-2022-3109.
-Corrected an OpenVPN vulnerability categorized as CWE-134.
-Fixed the Hostap vulnerability CVE-2019-10064.
-Patched a command injection vulnerability to improve overall security.
-Strengthened protection against SSH brute force attacks.
Looks like its out of beta! I'll be installing this on Thursday after everyone leaves the house.
Upgraded around 3hrs ago. Had to reset settings because of WiFi devices were not able to connect at all. I suppose its because of I had latest beta some time ago installed and did not reset after that.
Nothing special to add for 3hrs of uptime but all devices connected and no issues so far. We'll see is it stable or not.
Can you test something?
When you enable 160 mhz can your devices connect to the router? For me it doesn't work at all. I wonder if it has to do with the new firmware or the router. I just got this router 15 min ago. With my AX86U my devices connect fine with 160 mhz enabled.
All fine, everyone connected.
I installed this on my RT-AX88u Pro and now the client list on each node under aimesh is just empty on the GUI.
Asus has not released any new firmware for the Ax88Pro.
What are you talking about?
ASUS RT-AX88U Pro Firmware version 3.0.0.6.102_21514
Version 3.0.0.6.102_21514
66.97 MB
2023/06/20
-Multi-services WAN, create multiple profiles on a single WAN interface. (https://rog.asus.com/au/support/FAQ/1050072)
Security Fixes
Please unzip the firmware file, and then verify the checksum.
SHA256: 54ffd3850a950a516f5aada33ead264f1cc27771fbf182938bd5ecf985c2c0eb
66.97 MB
2023/06/20
Security Fixes
wierd. I hit refresh and now its gone. Wondered if they pulled it cause they definitely released one earlier today. Look at my screen shot.
Ok. Did not see any new version when i checked just before i posted. My bad. Still don't see it.
ya its gone, though my router is still showing its available
I doubt it. I updated just minutes ago from the GUI.
It couldn’t have been smoother. I didn’t even have to reboot.
Errr, guys, this is an AX6000 thread.
