Release ASUS RT-AX88U Firmware version 3.0.0.4.388_24209 (2024/03/29)
visortgw
Version 3.0.0.4.388_24209
67.79 MB
2024/03/29
Release notes:
- Fixed command injection vulnerability.
- Fixed the ARP poisoning vulnerability. Thanks to the contribution of Xin'an Zhou.
- Fixed code execution in custom OVPN. Thanks to the contrubution of Jacob Baines.
- Fixed the injection vulnerability in AiCloud.
- Fixed stack buffer overflow in lighttpd. Special thanks to Viktor Edstrom.
- Fixed CVE-2023-35720
- Fixed the code execution vulnerability in AiCloud. Thanks to the contribution of chumen77.
- Fixed the XSS and Self-reflected HTML injection vulnerability. Thanks to the contrubution of Redfox Cyber Security.
*Please be advised that due to a security upgrade in AiMesh, we strongly recommend against downgrading to previous firmware versions, as this may lead to connection issues. Should you encounter any difficulties, resetting the AiMesh router to its default settings and re-establishing the mesh connection can resolve the problem.
Please unzip the firmware file, and then verify the checksum.
SHA256: 4783ea5ae14a94ce3d78319fdbaccb3c3e09f4e918c9787f9a6b9aa492f1ff1a
Download
Uploaded to my wired backhaul aimesh with 2x ax88u. Seems ok. Having weekly hard resets required where wan and wireless go down. I see some new log entries around upnp. So far so good 24 hours in.
I skipped the last one because it was flaky. I hope this firmware is good!
I just updated mine and will report back if anything strange happens. Strange it doesn't show in the router search.
My router has yet to return to prior memory % levels but it's only been 1 day. 49% instead of 58. Nothing in patch notes about that.
Yes, and there never will be.
RAM is used as needed. Nothing extraordinary here.
I can attest this firmware is so much better than the previous (That I Skipped). Now my Mesh setup is so much balance.
