Cannot Stream from Router - Samba Problem
muffintastic
Everytime I stream from VLC on my phone (Android) using SMB protocol I keep getting these in the log;
Apr  1 10:47:35 RT-AX86U_Pro-9680 smbd[13141]: [2024/04/01 10:47:35.382414,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:35 RT-AX86U_Pro-9680 smbd[13141]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:42 RT-AX86U_Pro-9680 smbd[13163]: [2024/04/01 10:47:42.942795,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:42 RT-AX86U_Pro-9680 smbd[13163]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:43 RT-AX86U_Pro-9680 smbd[13166]: [2024/04/01 10:47:43.683678,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:43 RT-AX86U_Pro-9680 smbd[13166]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:44 RT-AX86U_Pro-9680 smbd[13169]: [2024/04/01 10:47:44.383579,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:44 RT-AX86U_Pro-9680 smbd[13169]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:45 RT-AX86U_Pro-9680 smbd[13178]: [2024/04/01 10:47:45.104431,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:45 RT-AX86U_Pro-9680 smbd[13178]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:45 RT-AX86U_Pro-9680 smbd[13182]: [2024/04/01 10:47:45.882698,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:45 RT-AX86U_Pro-9680 smbd[13182]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:46 RT-AX86U_Pro-9680 smbd[13185]: [2024/04/01 10:47:46.609882,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:46 RT-AX86U_Pro-9680 smbd[13185]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:47 RT-AX86U_Pro-9680 smbd[13188]: [2024/04/01 10:47:47.363386,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:47 RT-AX86U_Pro-9680 smbd[13188]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:48 RT-AX86U_Pro-9680 smbd[13191]: [2024/04/01 10:47:48.099671,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:48 RT-AX86U_Pro-9680 smbd[13191]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:48 RT-AX86U_Pro-9680 smbd[13194]: [2024/04/01 10:47:48.883066,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:48 RT-AX86U_Pro-9680 smbd[13194]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:49 RT-AX86U_Pro-9680 smbd[13197]: [2024/04/01 10:47:49.666031,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:49 RT-AX86U_Pro-9680 smbd[13197]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:50 RT-AX86U_Pro-9680 smbd[13210]: [2024/04/01 10:47:50.474532,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:50 RT-AX86U_Pro-9680 smbd[13210]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:51 RT-AX86U_Pro-9680 smbd[13212]: [2024/04/01 10:47:51.231494,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:51 RT-AX86U_Pro-9680 smbd[13212]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:52 RT-AX86U_Pro-9680 smbd[13215]: [2024/04/01 10:47:52.002361,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:52 RT-AX86U_Pro-9680 smbd[13215]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:52 RT-AX86U_Pro-9680 smbd[13219]: [2024/04/01 10:47:52.742616,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:52 RT-AX86U_Pro-9680 smbd[13219]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:53 RT-AX86U_Pro-9680 smbd[13222]: [2024/04/01 10:47:53.553153,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:53 RT-AX86U_Pro-9680 smbd[13222]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:47:54 RT-AX86U_Pro-9680 smbd[13224]: [2024/04/01 10:47:54.241967,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:47:54 RT-AX86U_Pro-9680 smbd[13224]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:54:28 RT-AX86U_Pro-9680 smbd[14838]: [2024/04/01 10:54:28.957682,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:54:28 RT-AX86U_Pro-9680 smbd[14838]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:54:41 RT-AX86U_Pro-9680 smbd[14890]: [2024/04/01 10:54:41.693580,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:54:41 RT-AX86U_Pro-9680 smbd[14890]:   init_smb_request: invalid wct number 255 (size 180)
Apr  1 10:54:51 RT-AX86U_Pro-9680 smbd[14924]: [2024/04/01 10:54:51.440008,  0] smbd/process.c:523(init_smb_request)
Apr  1 10:54:51 RT-AX86U_Pro-9680 smbd[14924]:   init_smb_request: invalid wct number 255 (size 180)
I'm running the latest version of Merlin; 3004.388.6_2 and accessing the share through Wireguard on my phone, it's setup correctly. It will stream 3 or 4 songs then VLC will report that the location no longer exists. I have a 500 GiB NVME attached to the USB 3.0 port.
Any solutions?
Can you remove "release" on top as you dont release anything.
