Noticing connection drops but can’t see why
dgraham78
I have been noticing that my connection disappears for a few minutes or so every so often, when I look at the router page it shows I’m connected but no access to the internet. Here is a log of the time frame when it last happened which was today. Anyone have any ideas?
Jul 11 11:15:25 RT-AX86U-21A8 spdMerlin: Retrieving data for WebUI charts
Jul 11 11:16:10 RT-AX86U-21A8 hostapd: eth7: STA 34:28:40:aa:f1:ca IEEE 802.11: disassociated
Jul 11 11:27:35 RT-AX86U-21A8 acsd: eth6: COEX: downgraded chanspec 0x1908 (10) to 0x100a (10): channel 4 used by exiting BSSs
Jul 11 11:30:01 RT-AX86U-21A8 spdMerlin: Starting speedtest using Frontier (Chicago, IL, United States) for WAN interface
Jul 11 11:30:26 RT-AX86U-21A8 spdMerlin: Speedtest results - Download: 177.55 Mbps (data used: 200.5 MB) - Upload: 194.43 Mbps (data used: 239.9 MB)
Jul 11 11:30:26 RT-AX86U-21A8 spdMerlin: Connection quality - Idle Latency: 4.95 ms (jitter: 1.15ms, low: 3.79ms, high: 5.93ms) - Packet Loss: 0.0%
Jul 11 11:30:26 RT-AX86U-21A8 spdMerlin: Retrieving data for WebUI charts
Jul 11 11:32:44 RT-AX86U-21A8 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
Jul 11 11:40:44 RT-AX86U-21A8 hostapd: eth7: STA b0:e5:ef:70:21:7e IEEE 802.11: disassociated
Jul 11 11:40:55 RT-AX86U-21A8 hostapd: eth7: STA f4:21:ca:96:18:9e IEEE 802.11: disassociated
Jul 11 11:40:56 RT-AX86U-21A8 hostapd: eth7: STA f4:21:ca:96:18:9e IEEE 802.11: associated
Jul 11 11:40:56 RT-AX86U-21A8 hostapd: eth7: STA f4:21:ca:96:18:9e RADIUS: starting accounting session 44224AFFD4B40D4C
Jul 11 11:40:56 RT-AX86U-21A8 hostapd: eth7: STA f4:21:ca:96:18:9e WPA: pairwise key handshake completed (RSN)
Jul 11 11:41:14 RT-AX86U-21A8 awsiot[28573]: awsiot start
Jul 11 11:42:29 RT-AX86U-21A8 hostapd: eth7: STA 94:ea:32:b5:c6:3b IEEE 802.11: associated
Jul 11 11:42:29 RT-AX86U-21A8 hostapd: eth7: STA 94:ea:32:b5:c6:3b RADIUS: starting accounting session C0506F0125903C23
Jul 11 11:42:29 RT-AX86U-21A8 hostapd: eth7: STA 94:ea:32:b5:c6:3b WPA: pairwise key handshake completed (RSN)
Jul 11 11:42:38 RT-AX86U-21A8 acsd: eth6: COEX: downgraded chanspec 0x1908 (10) to 0x100a (10): channel 3 used by exiting BSSs
