Thank you very much for the answer.Try in an Incognito window. Works fine for me.
May 5 07:05:40 custom_script: Running /jffs/scripts/pre-mount (args: /dev/sda unknown)
May 5 07:05:40 pre-mount: Unexpected filesystem type unknown for /dev/sda
Did not work for me on RT-AX86U PRO as..................
Lucky me there are a gazillion "john's" in this world - not so sure about the asuscomm bit ... cause I don't have one .Your username and asuscomm address are exposed in this message.
Ah ok, the link under the version number contains an asuscomm url that's why I presumed you had one, the combination of that and your username felt a bit riskyLucky me there are a gazillion "john's" in this world - not so sure about the asuscomm bit ... cause I don't have one ..
Trend Micro signature shows -- 2.372 Updated : 2023/08/24 16:46
Manual check shows up to date, but version and date aren't changing.
Ah ... gotcha ... and fixed - good catchAh ok, the link under the version number contains an asuscomm url that's why I presumed you had one, the combination of that and your username felt a bit risky
Btw, I still think you have or had ddns enabled with asuscomm, because the link ends up in South Africa the same country as in your profile.
Rmerlin address this in another thread (post #2) about a month ago:Is there a plan/path to bring OpenSSL to the 3.X versions? 1.1.1 is end of life.
See subsequent posts by RMerlin in that discussion.Having two separate versions of OpenSSL in parallel is very problematic, so I'd rather avoid that. Migration to OpenSSL 3.x will have to be done by Asus due to the large amount of closed source components also linking against it.
I already discussed it with Asus last spring, so they were aware that OpenSSL 1.1.1's EOL was coming this fall. I don't have anything else to share about their plans at this time. It will probably take them some time, some of their current components (like OpenVPN 2.4.x) are not compatible with it, so they will need to also update these other components first.
The move to OpenSSL 3.0 will be more complicated than moving to 1.1.1, as 3.0 is stricter. For instance, it will break a lot of existing OpenVPN configurations as 3.0 will reject older/weaker SHA signatures that are probably present on a lot of router's OpenVPN configurations that were done using these older hashes. Migrating to 3.0 will require all of these persons to reconfigure their OpenVPN servers, and deploy updated config files to all of their clients. So, it's not something trivial.
Old and known thing - use search..!?Hi, I'm wondering what the problem is right away as I only have the problem on the rt-ax86u pro and on the rt-ax86u it works perfectly without this message of mastiff as a spammer in the log and I tested the rt-ax86u pro from Asus' own site and the error disappeared but when returning, the error remains on Asuswrt-Merlin
Had this problem in the previous version and the same error on the alpha now the one I'm testing
Otherwise, I like Asuswrt-Merlin better than Asus' own
Welcome To SNBForums
