I´ve done this yesterday (family was out of home) just to be shure and it took me about 4 hours.Guest wifi 1 is playing up again, but this time it's disabling itself at random. Time for factory reset (bye-bye weekend) as I've not seen anyone else mentioning it.
It is still present: Systemlog -> TAB "General Log"
Did you clean your browsercache?
That was not a clean setup from scratch...set it up back, with my own config backed-up
That is correct.That was not a clean setup from scratch...
Done. New baseline backup for BACKUPMON.Don't forget fo back up your clean system!
2+ weeks in... steady as a rock.
Also working great in a busy household with work environment. AiMesh, Smart Connect, Add-Ons (as per signature) for 40-50 clients.2+ weeks in... steady as a rock.
same here!
For the RT-AX86U Pro, the Guest Network Pro (VLAN) stuff is only available in the 9.0.0.6.102.4856 Beta Version firmware. That specific feature is only available for a few Asus routers.I received my brand new AX86U-Pro last this weekend and I’m very happy it.
*I did looked for wired VLAN settings page, but reading the forums it isn’t there yet. I hope soon?
*Last Q. These AX86 Pro front lights are so bright in comparison with the (old AC86U), is there a way to dim these bright lights with a script or setting other than turn them off or tape them?
I believe y'all will find this is stuff they're implementing in/for their "business-class" units/firmware as Software Defined Network ing.For the RT-AX86U Pro, the Guest Network Pro (VLAN) stuff is only available in the 9.0.0.6.102.4856 Beta Version firmware. That specific feature is only available for a few Asus routers.
I received my brand new AX86U-Pro last this weekend and I’m very happy it. After a clean reset I didn’t touched it anymore and let it settle for a while on the latest first time Asuswrt-Merlin 3004.388.5. Then I configured my settings and installed some scripts. The first thing I noticed that there were no more Tainted kernels with scripts in comparison with my old, now retired RT-AC86U.I Played with Aimesh, WG, Wi-Fi Agile Multiband, Target wit time, WPA3, AX, etc. to get familiar with new settings and with a lot of fun. I still have to finetune some settings because several devices went down last night and didn’t come back up.
Some minor Q’s.
*My Wifi Site Survey page gives shows my connection is 10 MHz 54mbps with 1 one channel, while I’m at 5GHz, 160MHz at DFS and non DFS channels. Am I doing something wrong or Is this page broken or is this normal?
*I have no windows pc’s but I got spammed with dns.msftncsi.com every minute seeing the NextDNS Logs, not a big problem for me but that’s approx. 40k+ hits a month. Is this standard for the new AX routers? Maybe i setup Diversion to counter these hits before showing up at NextDNS. But would defeat its purpose.
Tnx!
Yeah the lights are bright. Looked high and low for a way to dim it via the GUI, nothing there other than On/Off for the lights apparently. I just leave them off. There is the bug in the GUI that one has to cycle the stupid button on then off if the lights come back on after making any changes to the router. Otherwise the lights are on but the button slider indicates the lights are off.
Welcome To SNBForums
