Thank you! after all had not read everything .....
You're very welcome.Thank you! after all had not read everything .....![]()
There is a newer one dated 1/1/2020(Wed at 9:40 PM)2nd alpha build 25dec working well on my AC5300 , no problems at all .
Thanks Merlin
Working fine on mine...dirty upgrade too!what is the difference between alpha1-g4fecf771de and alpha1-gea333a6048 because on the RT-AC5300 the
alpha1-gea333a6048 version installs where as the alpha1-g4fecf771de does not install?
I have been running this version on the RT-AX88U for 3 days and 12 hours now, no issues.
As far as the RT-AC5300 concerns: a definite YES! The to be expected signal strength on all wifi channels is back (384.14 had up to 8% less signal on my routers) , LAN-WAN throughput, CPU temp, it all works smooth. With MU-MIMO off the speed of my devices have up to 30% more speed. (No experience with QOS as it kills the performance of my vpn client). A quick and dirty upgrade works fine. Have the Alpha installed on my second router given the excellent experience on the first.do you recommend over the “stable” build 384.14?
Set up my router from scratch (without reloading any previous router settings) and everything seemed fine yesterday evening.
However, woke up this morning and DNS was again not working until I manually restarted the dnsmasq service.
Now that we ruled out (what some call) a “dirty” flash, what should I try next to debug/fix this?
I don’t use their beta client (DoH); I use the firmware built-in DoT (via Stubby).Judging by your post history you use NextDNS, are you sure the issue isn't with their beta client?
Jan 4 05:21:21 dnsmasq[21003]: query[A] www.meethue.com from 192.168.1.111
Jan 4 05:21:21 dnsmasq[21003]: forwarded www.meethue.com to 127.0.1.1
Jan 4 05:21:22 dnsmasq[21003]: forwarded www.meethue.com to 127.0.1.1
Jan 4 05:21:22 dnsmasq[21003]: validation www.meethue.com is BOGUS
Jan 4 05:21:22 dnsmasq[21003]: reply error is SERVFAIL
Jan 4 05:21:30 dnsmasq[21003]: query[A] www.meethue.com.home.lan from 192.168.1.111
Jan 4 05:21:30 dnsmasq[21003]: config www.meethue.com.home.lan is NXDOMAIN
Jan 4 08:10:08 dnsmasq[12296]: query[A] www.meethue.com from 192.168.1.111
Jan 4 08:10:08 dnsmasq[12296]: forwarded www.meethue.com to 127.0.1.1
Jan 4 08:10:08 dnsmasq[12296]: validation result is INSECURE
Jan 4 08:10:08 dnsmasq[12296]: reply www.meethue.com is 35.201.97.239
// Configure the firmware so:
// * Disable WAN DNS so dnsmasq does not set conflicting upstream servers.
// * DNS rebinding is disabled, as DNS blocking uses 0.0.0.0 to block domains.
// The rebinding protection can be setup and enforced at NextDNS level.
// * DNSSEC validation is disabled as when a DNSSEC supported domain is blocked,
// the validation will fail as blocking alters the response. NextDNS takes care
// of DNS validation for non blocked queries.
I think your issue is trying to stay with nextdns in spite of their problems and new growing pains. They have a new product available for testing soon from entware.Applying the changes above (disable WAN DNS, DNS rebinding, and DNSSEC validation) did not help; DNS still fails after some time...
EDIT: it apparently even resets back to "LAN only" without a router reboot...
I'm indeed going two steps back now:I think your issue is trying to stay with nextdns in spite of their problems and new growing pains. They have a new product available for testing soon from entware.
What was your decision to use NextDNS over Diversion? I think diversion does a great job at blocking content, even better now since you can load Pihole and other domain based lists.I'm indeed going two steps back now:
Only if these work fine I might go back to NextDNS, though I would really like to use their service.
- First try 1.1.1.1 without DNS over TLS
- Then try 1.1.1.1 with DNS over TLS
(And I want DoT; not their DoH solution)
Yes, I have SkyNet installed, but have had that for a long time and could always remote SSH.
@Adamm Did this change recently in SkyNet?
logger -st Skynet "[!] Insecure Setting Detected - Disabling WAN SSH Access"
Welcome To SNBForums
