[384.15_Alpha - builds] Testing all variants.
When the securemode setting is enabled (which it is by default), it prevents the user from exposing SSH and the WebUI to WAN, if you check the syslog you will see;
Ah, then this is the result of me nuking the router and starting from scratch...
(I just found it at lines 300 and forward)
Thanks for explaining!
There is a newer one dated 1/1/2020(Wed at 9:40 PM)
can't find it neest i see is 25 dec and wed 940 771DE trx , that would be the newest one ? the 6048 trx , the one i'm using is the older version . getting confused
Seems they both work on my 5300 GOING TO STICK WITH 771de trx
After returning to Cloudflare my router/DNS seems stable again, so it might have been NextDNS as suggested here.
Interesting new USB Application
I noticed on my RT-AC68U, running the latest Alpha that there is a new application on the USB Applications tab called FileFlex:
From any Internet connected device, remotely access and share all your files via your ASUS router.
(Third party software with one year free trial)
https://fileflex.com/
On my AX88U running the latest Alpha, I don't see it.
Asus only enabled it on the RT-AC68U. Might possibly be still a work in progress, or something they intend to only offer for some specific SKUs.
Is this logging showing correct behaviour?
Jan  4 05:21:21 dnsmasq[21003]: query[A] www.meethue.com from 192.168.1.111
Jan  4 05:21:21 dnsmasq[21003]: forwarded www.meethue.com to 127.0.1.1
Jan  4 05:21:22 dnsmasq[21003]: forwarded www.meethue.com to 127.0.1.1
Jan  4 05:21:22 dnsmasq[21003]: validation www.meethue.com is BOGUS
Jan  4 05:21:22 dnsmasq[21003]: reply error is SERVFAIL
What is 127.0.1.1?
Here is what I get when looking up meethue.com over TLS DNS to Cloudflare. I think 127.0.1.1 is where Asuswrt-Merlin integrated stubby is listening.
Jan  5 13:33:44 dnsmasq[28545]: 5977 query[A] www.meethue.com from 2601:18f:800:b426:a995:afd:9de:1070
Jan  5 13:33:44 dnsmasq[28545]: 5977 forwarded www.meethue.com to 127.0.1.1
Jan  5 13:33:44 dnsmasq[28545]: 5978 query[AAAA] www.meethue.com from 2601:18f:800:b426:a995:afd:9de:1070
Jan  5 13:33:44 dnsmasq[28545]: 5978 forwarded www.meethue.com to 127.0.1.1
Jan  5 13:33:44 dnsmasq[28545]: 5978 reply www.meethue.com is NODATA-IPv6
Jan  5 13:33:44 dnsmasq[28545]: 5979 query[A] www.meethue.com from 192.168.50.200
Jan  5 13:33:44 dnsmasq[28545]: 5979 forwarded www.meethue.com to 127.0.1.1
Jan  5 13:33:44 dnsmasq[28545]: 5979 reply www.meethue.com is 35.201.97.239
Jan  5 13:33:44 dnsmasq[28545]: 5977 reply www.meethue.com is 35.201.97.239
Jan  5 13:33:44 dnsmasq[28545]: 5980 query[A] www2.meethue.com from 2601:18f:800:b426:a995:afd:9de:1070
Jan  5 13:33:44 dnsmasq[28545]: 5980 forwarded www2.meethue.com to 127.0.1.1
Jan  5 13:33:44 dnsmasq[28545]: 5981 query[AAAA] www2.meethue.com from 2601:18f:800:b426:a995:afd:9de:1070
Jan  5 13:33:44 dnsmasq[28545]: 5981 forwarded www2.meethue.com to 127.0.1.1
Jan  5 13:33:44 dnsmasq[28545]: 5980 reply www2.meethue.com is <CNAME>
Jan  5 13:33:44 dnsmasq[28545]: 5981 reply www2.meethue.com is <CNAME>
Yes it seems only available for the 68U
https://asus-info.fileflex.com/
Will be a paid service: ASUS RT-AC68U routers now include a 1 year single user pre-paid subscription to FileFlex ($34.95 value)
It seems to be the next insecure service provided (following the Asus smartphone app) :) Sorry Asus, but the only way to access anything behind the router is still the good old VPN :)
Hell from Germany, i have a bug
I'm using the 384.15_alpha1-gd9c8b621c5 build on my new AX88U router. Not sure if it's just an alpha bug, but the "b/g protection" check box is fixed and grayed out, and I have the 2.4 GHz network set to "N only."
Does the "b/g protection" do anything when the network is set to N only?
That feature is only available when "Legacy" is used as a setting.
Thanks. Then it must be a bug since it shows up and cannot be unchecked.
No. Legacy means lower than "N" thats why it becomes available. When using "N" only you don't want a/b interference, so it's selected and greyed out.
