[384.9_Alpha - builds] Testing all variants.
With the RT-AC1900P I notice that clicking the Apply button in Administration/System does nothing in FF and Chrome. The Apply button appears to work on other pages.
Also, two instances of dnsmasq are running. One as user nobody, the other as admin, even without a plugged in USB stick, so no Diversion services are active:
201     1 nobody   S     1260  0.4   0  0.0 dnsmasq --log-async
202   201 tadmin      S     1252  0.4   0  0.0 dnsmasq --log-async
I tried it in Safari but Apply did not work on my Bridge Mode. Was trying to turn off the reboot scheduler and couldn’t not save it as a result.
Did a dirty upgrade to a1 from 384.8_2. Thanks for your hard work. Now running for 8+ hrs. Seems solid so far. I did need to reinstall Skynet. Here a couple of nits and other info:
1. typo - Administration\System\
Basic Config
"Resvolved Target"
2. Tools\SysInfo\Network - 5G device counts = 0, even though System Log\Wireless Log shows 3 devices
3. Wan tab does not completely display in my browser unless I do a number of refreshes. This is the only page that I have seen this. But I also saw this in previous versions (sorry, forgot to report). I am currently using Vivaldi although I have seen it also in FF.
4. Once when I was entering in a revised password for a 5G Guest Network, I got a display that said something about the need to change my WiFi parameters, then the 86U became unresponsive. I needed to physically reboot then all was fine.
5. I saw this in the logs. This does not sound right. Looks like this is happening about every 20 min or so.
Dec 27 07:25:20 kernel: dcd[27605]: unhandled level 3 translation fault (11) at 0x00000000, esr 0x92000007
Dec 27 07:25:20 kernel: pgd = ffffffc0061b8000
Dec 27 07:25:20 kernel: [00000000] *pgd=0000000005dc8003, *pud=0000000005dc8003, *pmd=0000000008dac003, *pte=0000000000000000
Dec 27 07:25:20 kernel: CPU: 1 PID: 27605 Comm: dcd Tainted: P O 4.1.27 #2
Dec 27 07:25:20 kernel: Hardware name: Broadcom-v8A (DT)
Dec 27 07:25:20 kernel: task: ffffffc0124f80c0 ti: ffffffc007398000 task.ti: ffffffc007398000
Dec 27 07:25:20 kernel: PC is at 0xf7397f44
Dec 27 07:25:20 kernel: LR is at 0x1dc74
Dec 27 07:25:20 kernel: pc : [<00000000f7397f44>] lr : [<000000000001dc74>] pstate: 600e0010
Dec 27 07:25:21 kernel: sp : 00000000ffa03cd8
Dec 27 07:25:21 kernel: x12: 000000000009ff10
Dec 27 07:25:21 kernel: x11: 00000000f66ff024 x10: 00000000000a02b4
Dec 27 07:25:21 kernel: x9 : 00000000f66ffc60 x8 : 00000000000a076c
Dec 27 07:25:21 kernel: x7 : 00000000f66ffc98 x6 : 00000000000a0766
Dec 27 07:25:21 kernel: x5 : 0000000000000000 x4 : 00000000f66ffc44
Dec 27 07:25:21 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Dec 27 07:25:21 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Installed on my AX88U last night but none off my devices can see 5G WiFi at all, did a power down of the router for 5 mins but still no luck.
Any ideas how to fix?
rt-ac3200 working very well ...
Seen that and there is no real answer to this. I don't believe all these devices are disconnecting and reconnecting every minute or so.
Is the log file in danger of growing to big? @RMerlin What should I do?
Log files are rotated, so no.
Either ignore them, or write a script to "clean" your log file if you're really that bothered.
success on 3200 , so far everything works , thanks Merlin you did well , and thanks for the fresh FW , 6months with the old FW WAS A bit much
Apply button not working on admin/system page cannot change to https or app, or other any changes on page , is there a fix for this , with FF AND CHROME browser
aso notice CPU temp has gone up 8 degrees and insteadof 64 mb of ram used now steady at 134mb of ram used, nothing other than these differences , works well though
Upgraded without any issue for 3200 from 384.6. Thank you so much for the wonderful work, Eric! CPU temp was 69 before, now 68. RAM used was 66 MB before, and 61 now. Apply button not working either using IE.
that is odd your temp went down as well as ram usage , opposite of my 3200 , wonder what i've done this time
Also seeing whatever it is fall over with some regularity on AC86U / 384.9_a1, but all else seems stable. Even the wifi connected clients list seems stable, which it never has been for me.
Dec 27 21:43:53 kernel: pgd = ffffffc0061b6000
Dec 27 21:43:53 kernel: [00000000] *pgd=00000000094f7003, *pud=00000000094f7003, *pmd=0000000007251003, *pte=0000000000000000
Dec 27 21:43:53 kernel: CPU: 1 PID: 2297 Comm: dcd Tainted: P           O    4.1.27 #2
Dec 27 21:43:53 kernel: Hardware name: Broadcom-v8A (DT)
Dec 27 21:43:53 kernel: task: ffffffc019338a80 ti: ffffffc0061f4000 task.ti: ffffffc0061f4000
Dec 27 21:43:53 kernel: PC is at 0xf70f9f44
Dec 27 21:43:53 kernel: LR is at 0x1dc74
Dec 27 21:43:53 kernel: pc : [<00000000f70f9f44>] lr : [<000000000001dc74>] pstate: 600e0010
Dec 27 21:43:53 kernel: sp : 00000000fff86388
Dec 27 21:43:53 kernel: x12: 000000000009ff10
Dec 27 21:43:53 kernel: x11: 00000000f63ff024 x10: 00000000000a02b4
Dec 27 21:43:53 kernel: x9 : 00000000f63ff6d0 x8 : 00000000000a076c
Dec 27 21:43:53 kernel: x7 : 00000000f63ff708 x6 : 00000000000a0766
Dec 27 21:43:53 kernel: x5 : 0000000000000000 x4 : 00000000f63ff6b4
Dec 27 21:43:53 kernel: x3 : 0000000000000000 x2 : 00000000fff86364
Dec 27 21:43:53 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Dec 27 21:47:58 kernel: pgd = ffffffc00377c000
Dec 27 21:47:58 kernel: [00000000] *pgd=00000000061d7003, *pud=00000000061d7003, *pmd=0000000006acf003, *pte=0000000000000000
Dec 27 21:47:58 kernel: CPU: 1 PID: 5626 Comm: dcd Tainted: P           O    4.1.27 #2
Dec 27 21:47:58 kernel: Hardware name: Broadcom-v8A (DT)
Dec 27 21:47:58 kernel: task: ffffffc0132a6bc0 ti: ffffffc009240000 task.ti: ffffffc009240000
Dec 27 21:47:58 kernel: PC is at 0xf73fcf44
Dec 27 21:47:58 kernel: LR is at 0x1dc74
Dec 27 21:47:58 kernel: pc : [<00000000f73fcf44>] lr : [<000000000001dc74>] pstate: 600e0010
Dec 27 21:47:58 kernel: sp : 00000000ff872ec8
Dec 27 21:47:58 kernel: x12: 000000000009ff10
Dec 27 21:47:58 kernel: x11: 00000000f66ff024 x10: 00000000000a02b4
Dec 27 21:47:58 kernel: x9 : 00000000f66ff6d0 x8 : 00000000000a076c
Dec 27 21:47:58 kernel: x7 : 00000000f66ff708 x6 : 00000000000a0766
Dec 27 21:47:58 kernel: x5 : 0000000000000000 x4 : 00000000f66ff6b4
Dec 27 21:47:58 kernel: x3 : 0000000000000000 x2 : 00000000ff872ea4
Dec 27 21:47:58 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Dec 27 21:53:07 kernel: pgd = ffffffc013156000
Dec 27 21:53:07 kernel: [00000000] *pgd=0000000017075003, *pud=0000000017075003, *pmd=0000000006d9f003, *pte=0000000000000000
Dec 27 21:53:07 kernel: CPU: 1 PID: 5997 Comm: dcd Tainted: P           O    4.1.27 #2
Dec 27 21:53:07 kernel: Hardware name: Broadcom-v8A (DT)
Dec 27 21:53:07 kernel: task: ffffffc0171295c0 ti: ffffffc002d48000 task.ti: ffffffc002d48000
Dec 27 21:53:07 kernel: PC is at 0xf73bbf44
Dec 27 21:53:07 kernel: LR is at 0x1dc74
Dec 27 21:53:07 kernel: pc : [<00000000f73bbf44>] lr : [<000000000001dc74>] pstate: 600e0010
Dec 27 21:53:07 kernel: sp : 00000000ffb8a138
Dec 27 21:53:07 kernel: x12: 000000000009ff10
Dec 27 21:53:07 kernel: x11: 00000000f66ff024 x10: 00000000000a02b4
Dec 27 21:53:07 kernel: x9 : 00000000f66ff6d0 x8 : 00000000000a076c
Dec 27 21:53:07 kernel: x7 : 00000000f66ff708 x6 : 00000000000a0766
Dec 27 21:53:07 kernel: x5 : 0000000000000000 x4 : 00000000f66ff6b4
Dec 27 21:53:07 kernel: x3 : 0000000000000000 x2 : 00000000ffb8a114
Dec 27 21:53:07 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Dec 27 22:21:13 kernel: pgd = ffffffc014fe3000
Dec 27 22:21:13 kernel: [00000000] *pgd=0000000003a73003, *pud=0000000003a73003, *pmd=000000001314f003, *pte=0000000000000000
Dec 27 22:21:13 kernel: CPU: 1 PID: 6345 Comm: dcd Tainted: P           O    4.1.27 #2
Dec 27 22:21:13 kernel: Hardware name: Broadcom-v8A (DT)
Dec 27 22:21:13 kernel: task: ffffffc0192e0b40 ti: ffffffc006a7c000 task.ti: ffffffc006a7c000
Dec 27 22:21:13 kernel: PC is at 0xf6e83f44
Dec 27 22:21:13 kernel: LR is at 0x1dc74
Dec 27 22:21:13 kernel: pc : [<00000000f6e83f44>] lr : [<000000000001dc74>] pstate: 600e0010
Dec 27 22:21:13 kernel: sp : 00000000ffce91a8
Dec 27 22:21:13 kernel: x12: 000000000009ff10
Dec 27 22:21:13 kernel: x11: 00000000f61ff024 x10: 00000000000a02b4
Dec 27 22:21:13 kernel: x9 : 00000000f61ff6d0 x8 : 00000000000a076c
Dec 27 22:21:13 kernel: x7 : 00000000f61ff708 x6 : 00000000000a0766
Dec 27 22:21:13 kernel: x5 : 0000000000000000 x4 : 00000000f61ff6b4
Dec 27 22:21:13 kernel: x3 : 0000000000000000 x2 : 00000000ffce9184
Dec 27 22:21:13 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Dec 27 22:49:12 kernel: pgd = ffffffc013189000
Dec 27 22:49:12 kernel: [00000000] *pgd=000000000377c003, *pud=000000000377c003, *pmd=0000000014c27003, *pte=0000000000000000
Dec 27 22:49:12 kernel: CPU: 1 PID: 8587 Comm: dcd Tainted: P           O    4.1.27 #2
Dec 27 22:49:12 kernel: Hardware name: Broadcom-v8A (DT)
Dec 27 22:49:12 kernel: task: ffffffc01933a0c0 ti: ffffffc002d48000 task.ti: ffffffc002d48000
Dec 27 22:49:12 kernel: PC is at 0xf6e4ef44
Dec 27 22:49:12 kernel: LR is at 0x1dc74
Dec 27 22:49:12 kernel: pc : [<00000000f6e4ef44>] lr : [<000000000001dc74>] pstate: 600e0010
Dec 27 22:49:12 kernel: sp : 00000000ff92fae8
Dec 27 22:49:12 kernel: x12: 000000000009ff10
Dec 27 22:49:12 kernel: x11: 00000000f60ff024 x10: 00000000000a02b4
Dec 27 22:49:12 kernel: x9 : 00000000f60ff6d0 x8 : 00000000000a076c
Dec 27 22:49:12 kernel: x7 : 00000000f60ff708 x6 : 00000000000a0766
Dec 27 22:49:12 kernel: x5 : 0000000000000000 x4 : 00000000f60ff6b4
Dec 27 22:49:12 kernel: x3 : 0000000000000000 x2 : 00000000ff92fac4
Dec 27 22:49:12 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Just over 17hours on 384.9 alpha 1 on my ac68u and no problems to report other than the usual error 03:40:20 kernel: ERR[update_qos_data_by_mac:3585] Failed to find udb entry by skb src-MAC!
Ive been putting my router through its paces to, I’m really impressed so far with this build :)
Turned on AiProtection to show a neighbour the settings .
Log shows this every 2 minutes :
Dec 28 07:02:10 kernel: Anomaly Undefined op out 2
Stops when AiProtection is shut down.
Dirty upgrade from 384.6 AC3200. working well - thanks!!
one minor thing I noted
wireless->roaming block list
results in a 404
same here on my 3200 , log is filled with that undefinedanomaly opt out 2
wonder what it is ?
just done factory default and the apply button is not working on administration->system tab ?
AC3200.
is there way to set the enable jffs to true via some commands ?
AC3200.
nvram set jffs2_scripts=1
nvram commit
