Return to last stable firmware? That's what I did. It's an alpha version, bugs are expected.ok but now how to execute it when ssh not accessible ?
thanks that fixed log entries and high ram usage now back at 64 mb ram instead o 136mb and temps droped 3 deg on cpuTurned on AiProtection to show a neighbour the settings .
Log shows this every 2 minutes :
Code:Dec 28 07:02:10 kernel: Anomaly Undefined op out 2
Stops when AiProtection is shut down.
So you would rather turn off a security feature so you can run an alpha?thanks that fixed log entries and high ram usage now back at 64 mb ram instead o 136mb and temps droped 3 deg on cpu
just done factory default and the apply button is not working on administration->system tab ?
AC3200.
is there way to set the enable jffs to true via some commands ?
On my AC86U I have to enter my password in both fields to get the Apply button to work.
Good catch!
I’ll try it later.
I thought I would try it. I selected usb2 (it was set to usb3) clicked apply and it rebooted the router. The setting took just fine. AC3100.I tried it. It does not resolve the problem with the "Apply Button" not working...
So you would rather turn off a security feature so you can run an alpha?![]()
& another thing, I’m not seeing any AiProtect IPS complaints with 384.9 alpha1.
Normally I see dozens per day, go figure?
i know, but i like this one ...Return to last stable firmware? That's what I did. It's an alpha version, bugs are expected.
my compters are well protected , no problems so farhave never used the trend on the router until this update , not worried without trend and if it fills the log with garbage and uses double the ram . i'll keep it offSo you would rather turn off a security feature so you can run an alpha?![]()
Issue is present also on RT-AC68I tried it. It does not resolve the problem with the "Apply Button" not working...
I’ve just checked my 68u and it matches yours.Issue is present also on RT-AC68
Welcome To SNBForums
