Adam Williamson
how come no rt-ac86u alpha
patience.... coming soon near youhow come no rt-ac86u alpha
Generally it means Asus hasn't (yet) posted newer build files for that model to RMerlin for him to compile.how come no rt-ac86u alpha
I started typing something similar yesterday and then promptly forgot about it but here it is:RT-AC68U dirty flash over 386.4 Seems more stable than 386.4 on the RT-AC68U which is unheard of for an Alpha release!
Likely thanks to this...I started typing something similar yesterday and then promptly forgot about it but here it is:
Alpha 1 seems to be better with my RT-AC68P and FlexQoS under high QoS load scenarios:
I have 120/18 speed and activities with lots of small packets can max out the processor on download when QoS is active - 100% on core 1 with very high sirq - large packets don't do that)
With 386.4 I noticed sluggishness aka latency increase in other activities when that happens.
With 386.5 Alpha 1 everything remains snappy even when Core 1 is 100% busy....
Maybe something sirq related got optimized with the new Asus portion since all the busy comes from sirq activities.
It would not change Adaptive QoS behavior.Likely thanks to this...
Assorted TQoS fixes by kjbracey2 · Pull Request #800 · RMerl/asuswrt-merlin.ng
Fix transfer limits - undefined behaviour was stopping minimums from working Allow default rule to work when a transfer limit rule no longer applies Basic IPv6 support Fix imq0 download classificat...github.com
LOL, well I've been wrong before... Thanks for the correction (as Nobody knows FlexQoS) much better than you.It would not change Adaptive QoS behavior.
Don’t tempt me to install an alpha!!RT-AC68U dirty flash over 386.4 Seems more stable than 386.4 on the RT-AC68U which is unheard of for an Alpha release!
Feb 16 21:21:30 RT-AX88U-6C58 kernel: ** ERROR: [send_redir_page:625] # redir_url=https://192.168.1.1:8443/blocking.asp?cat_id=23&mac=*******C8428&domain=yield-op-idsync.live.streamtheworld.com
Feb 16 21:21:50 RT-AX88U-6C58 kernel: ** ERROR: [send_redir_page:625] # redir_url=https://192.168.1.1:8443/blocking.asp?cat_id=23&mac=*******B5023&domain=acds.prod.vidible.tv
Feb 16 21:06:41 RT-AX88U-6C58 kernel: httpds (1261): drop_caches: 1
Feb 16 21:12:13 RT-AX88U-6C58 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
When you login to the firmware this entry happens.Feb 16 21:06:41 RT-AX88U-6C58 kernel: httpds (1261): drop_caches: 1
I have the same error and have no clue what it is.Feb 16 21:12:13 RT-AX88U-6C58 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
I have the same router and don't have that issue.bug
in Main_WStatus_Content.asp RT-AX88U cannot see WIFI clients connect
Welcome To SNBForums
