Read on SmallNetBuilder
Tim, Netgear are not doing it alone and are now partnered with Netduma who created the OSNETGEAR's CES 2018 introductions include something for gamers, business and babies.![]()
Will this get the up and coming WPA3 I wonder? Will it take a 63 character ASCII password, unlike my R7800So many questions. Think I'll stick with my R7800 for now. Gone are my bleeding edge days with Netgear.
Considering none of my other devises support it and I’m not replacing them all I’m not to worried. I can see like Krack a lot of devices won’t be updated like sound bars blue ray players smart TV’s etc.A better question (for me) is will my R7800 get WPA3 via a firmware update?
It’s probably pretty much the same plus the extra 128 MB of NAND flash. Initial OS testing was done on the R7800 prior to release. Basically Duma overlay with one of the settings in the menu labeled as “Netgear Settings” which contains the main settings you would see in a standard Netgear router laid out as usual.
Specs are totally the same, r7800 has the same 128mb flash and 512mb ram, if the CPU is the same its just a R7800 in disguise with optimisations to make people spend more money.It’s probably pretty much the same plus the extra 128 MB of NAND flash. Initial OS testing was done on the R7800 prior to release. Basically Duma overlay with one of the settings in the menu labeled as “Netgear Settings” which contains the main settings you would see in a standard Netgear router laid out as usual.
they share the same FCC ID and hardwareinterested to see r7800 vs. xr500...
So Netgear finally let go of the firmware side and that's the only difference apart from the oh so aggressive gamer stylingthey share the same FCC ID and hardware![]()
Announcement said there was more flash. Spec sheet NETGEAR sent as part of press package says:The XR500 has 256 MB NAND vs 128 MB NAND in the R7800.
Memory: 128 MB flash and 512 MB RAM
Maybe the new firmware wont have so many really bad bugs and ancient GPL like Netgears does presently, that's what I am hoping. Bugs like not letting QoS set priority for some users or wifi password who have a certain password length/type a weird bug where some 63 character ASCII passwords work and some don't (fine in previous versions since release firmware)Killhippie even stock R7800 firmware is OpenWRT based. Granted it’s the older 12.09 Attitude Adjustment I believe. The XR500 has 256 MB NAND vs 128 MB NAND in the R7800.
Welcome To SNBForums
