smadremanden
I would suppose never, as that would require merging it into the build of rmerlin or maintaining a fork of the build. Simple answer, it's just too much work
Super @digimon04 now you simply copy from # generated by AB-Solution 1.07 and onwards into the post-mount script, then do a reboot and presto! You have both up and running!![]()
Change that devices DNS settings to use Googles or something instead of the routers. Like 8.8.8.8Hi all,
I love to use ab-solution because it's easy and works great on my RT-AC3200.
My internet experience is much better than before.
I've only one problem, there's one user who loves to click on all the advertisement links who pop up at first in Google.
Is there a way to exclude a device from using ab-solution, while everyone else can have the benefits from ab-solution?
Kr.
Patrick
Thanx mate,Change that devices DNS settings to use Googles or something instead of the routers. Like 8.8.8.8
1.08 currently is the latest and greatest. This will change as soon as time permits.There will be other versions of this great tool or this is the last one?
I agree. But the official release will never include an adblocker, RMerlin stated this several times. I have done some work in that direction and it involves a lot of jumps and tricks to sideload an UI into the existing firmware. A complete build of a separate "includes adblocking" firmware of his releases would be simpler to make from what I can tell so far.this would be awesome integrated into the UI by merlinreally needs a UI imho...
When I run the WGET command that you have on page one of this thread, it installs version 1.07 yet you say 1.08 is the latest. Can you please provide the correct command to install 1.08?
Thanks.
I've tried that and I can't get it to show anything but 1.07 as the version.
Delete the previous file on your router first, then wget the 1.08 with:I've tried that and I can't get it to show anything but 1.07 as the version.
wget www.ab-solution.info/releases/beta/ab-solution.sh
curl -O www.ab-solution.info/releases/beta/ab-solution.sh
I'm sorry, but how do I delete the old file?Delete the previous file on your router first, then wget the 1.08 with:
or even better using curl:Code:wget www.ab-solution.info/releases/beta/ab-solution.sh
Code:curl -O www.ab-solution.info/releases/beta/ab-solution.sh
Thread starter | Title | Forum | Replies | Date |
C | Is there any easy solution in Merlin for a VPN server that is hard to block/detect? | Asuswrt-Merlin | 15 | |
[SOLUTION] WAN_Connection: ISP's DHCP did not function properly | Asuswrt-Merlin | 6 |
Welcome To SNBForums
