No, it's not normal because the [p] option works 100%.I added amazon-adsystem.com to my whitelist or amazon app on android doesn't work.
But once I did it I have to launch ab-solution and select "U" option. The "P" option is not enough.
Is it normal?
Can you tell, is there an effect in having ab-solution installed provided that all home users already have adblock (or ublock) in the browser?
afaik running an ad blocker from router is usually not detected from the websites that block you from seeing their content.Can you tell, is there an effect in having ab-solution installed provided that all home users already have adblock (or ublock) in the browser?
Looks doable. I'll try to squeeze the mail function in for the next release.@thelonelycoder is it possible to send the weekly status by email ?
like this script here
https://github.com/RMerl/asuswrt-merlin/wiki/Sending-Email
I'm not a script guy, I see that the dates of stats file is changing weekly, how can instruct it to send the latest stats file
I want setup a cron to generate the stats weekly and send it by mail, can you if possible create a small script for that ?
everyone can change/update their own gmail address/password
Thanks again for all your effort!!
At my place, none of the devices uses a separate ad-blocker. That is and always was my desire. Maintaining all the blockers on computers and phones is cumbersome, especially for the non-rooted iOS devices.Can you tell, is there an effect in having ab-solution installed provided that all home users already have adblock (or ublock) in the browser?
i have many devices on my network so having the router based blocker is easier to maintain but we still use adblocker on chrome/firefox so we dont get the https broken link icon.
i couldnt find a good tut to implement pixelserv tls w/ab, mind u i didnt look very hard and/or to much config to setup so hence the browser addon, easy peasy.On the first point, I think many still can because I see the nanny messages. I think it might be that many looked to see if the height of an ad was 0, so pixelserv might work. I see now some are testing for a height of more than 2.
On the second point, try pixelserv-tls.
pixelserv - A Better One-pixel Webserver for Adblocki couldnt find a good tut to implement pixelserv tls w/ab, mind u i didnt look very hard and/or to much config to setup so hence the browser addon, easy peasy.
i know thelonelycoder was toying w/the idea of adding pixelserv w/ab
Unrooted phones often can't block ads, so they'd be able to have an ad-free experience with ab-solution. The same might well be true for some people's preferred browsers - Safari, for example, doesn't have an ad blocker as far as I know.
That idea will be among the other goodies coming with the next version of AB-Solution.i know thelonelycoder was toying w/the idea of adding pixelserv w/ab
You, and maybe others, will be delighted by the now completed 'send as email' function. Coming to a router near you with the well advanced next version.@thelonelycoder is it possible to send the weekly status by email ?
I'm very aware of Pi-Hole. I have a Raspberry Pi just to get ideas for AB-Solution...that's good news, thank you
maybe too much to ask, why not a webif dashboard using lighttpd to serve a status page like pihole where you can also manage the white/blacklist items directly
https://github.com/pi-hole/AdminLTE
Thank you!I am very satisfied with this application.
Uh hm. How should I tell you? You wont like this news (to you)...But I can't edit and process my whitelist recently. When I
curl -O https://raw.githubusercontent.com/decoderman/AB-Solution/master/ab-solution.sh, it urges me to upgrade the AB-solution.
sh /tmp/mnt/<your device>/ab-solution.sh
sh ab-solution.sh
Version 2.0.1 does indeed remove the entries in /post-mount and removes /services-start if found (sorry my oversight).I am now considering upgrading the AB-Solution from version 1.07. I'd like to know if the upgrade remove the existing post-mount (consists of Entware entries) ? Do I need to re-create the whitelist? Thanks.
I'm also slightly curious.TLC: Slightly curious if you intend, while incorporating pixelserv-tls, to use the Entware version or the static binary version.
Thread starter | Title | Forum | Replies | Date |
C | Is there any easy solution in Merlin for a VPN server that is hard to block/detect? | Asuswrt-Merlin | 15 |
Welcome To SNBForums
