Android or iOS?
Android.
As I said, I have no issues with the ad-blocking script turned off. The issues only start when it is turned on. The blocking file that I'm using is shooter40sw.
Android or iOS?
Android.
I've switched to standard. I'll see if it makes a difference.Ah ok did you try with a little file?
I'm on standard and have no issues like that.
If it works on standard then there's some url which needs to be unblocked and for that you can use the ABSolution logging function to make a guess.
That's the best way to go, I use it for my local servers.How do I go about adding some dnsmasq records while using Ab-Solution? Do I just follow the normal dnsmasq records solution to hardcode some domains to internal IPs like suggested here?
https://github.com/RMerl/asuswrt-merlin/wiki/Custom-domains-with-dnsmasq
I did that and put the records in but nothing points to those IPs when I try to go to the domains I have entered. I've even tested direct from the router and it doesn't seem to work. Help?
Noted, not working here either.@thelonelycoder I just want to tell you that, I can't access to https://adblock.mahakala.is/ I think it's down that's why my router can't download list in this web site.
Well... it doesn't work if that is the case.That's the best way to go, I use it for my local servers.
Do check the Last steps in your linked tutorial.
Strange... it didn't work and then it did. Well, I guess I'm good for now.That's the best way to go, I use it for my local servers.
There are several amazon.com hosts in @thelonelycoder's updated default whitelist that is contained in the following post:I read somewhere there is a fix to the problem of Android OS accessing to Amazon. Adding some links to the whitelist file. Sorry I couldn't find the post mentioned here.
Swap file is used by the router itself, and therefore everything running on it. You don't need to do anything else if you've already created one!Hi! I'm sure this has been asked about before, but the search makes it hard to find. I got a 512MB swap file dnscrypt made. In AB-Solution I have 'swap file [-f]', and when I try to make one it wants to remove the dnscrypt swapfile. Should I do that, and will dnscrypt make use of AB-Solution's one?
512MB should be plenty, I have 384MB on my 87U and haven't ran into any memory issues running a whole host of scripts.Thank you! Is 512MB that DNSCrypt made enough for both? Have to uninstall DNSCrypt to get rid of the swap file it seems. AB-Solutions fails to remove it, and it isn't possible to rm it.
I have got a AC87U.
Based upon my personal experience, adding those hosts will resolve the issue with accessing Amazon from the Android app.
any solution?Maybe is a stupid question, but I already searched without finding something.
BACKUP.
I use rsnapshot to backup the external HDD, and I would also backup entware and others scripts configuration.
AB-Solution has the possibility to backup through e-mail, but I can't find a command to simply get the tar.gz archive with the config file (the same which is attached to the e-mail).
I'm looking for a command like SkyNet's firewall debug backup .
Thanks.
I can't install ab-solution, it just keeps timing out. I had to reset everything because my WiFi wasn't functioning on Merlin's firmware. I was able to install AMTM but even that wont install absolution.
Then, when I exit ssh and try to log back in and I type AMTM like I used to do to start that program it gets an error message.
It seems like everything from the lonely coder isn't working for me for some reason. I mean I tried 3 different firmware's and factory hard reset the router 3 times and this continues to happen.
Did you try a different USB drive?
Welcome To SNBForums
