AB-Solution - The Ad Blocking Solution
I had an error trying to update:
Updated mine to 3.8 without problems.
Just got a tiny warning:
Warning:
DNS-based Filtering is enabled on this router
This may or may not work with AB-Solution
Disable it after installation if ad-blocking
does not work and see if that helps.
This is because I have excluded my Sony Television from ad blocking:
This is how you exclude clients from ad blocking:
Go to /Parental Controls/DNS-Filtering/
- set 'Enable DNS-based Filtering' to ON
- set 'Global Filter Mode' to 'NO filtering'
- fill in 'Custom (user-defined) DNS 1' with, for example, Google's DNS 8.8.8.8
- select your client(s) in the Client List and set 'Filter Mode' 'Custom 1'
- click Apply
Now the client(s) in the Client list get the DNS from google and not from your router. This is how you exclude clients from ad blocking.
Ad blocking seems to work fine anyway (with other devices).
I've updated my RT-AC86U to the latest Merlin 380.65_4. Cleared nvram, reformatted USB stick & config the router from fresh. Installed AB-Solution 3.8 and got a warning pixelserv would not work due to too old firmware. After AB finished installation, I tried to install ps but got an error as below
Error: Your router's firmware (380.65) is too
old and not capable to run pixelserv-tls.
Upgrade your routers firmware first.
Should I downgrade to an older version of Merlin?
Thanks!
Working great thank you @thelonelycoder
tmp/mnt/sda1# ./ab-solution.sh
./ab-solution.sh: line 3099: syntax error: unexpected end of file (expecting "fi")
Im going to try to remove everything and install
__________________
I removed the adblocking folder and sh downloaded again y setup from scratch to get it to work again, it tried to update but after the error above when executing again it would say access denied.
That might be a transmission error, try the curl command first before reinstalling everything.
Thanks!
Let me test that on a real router version before you do anything, I only tested version numbers with dashes virtually.
Thanks for reporting!
Thanks!
As expected, that worked without a hitch on my RT-AC66U on 380.65_4, the problem is not the firmware version number, but the router listens on IP 0.0.0.0 on port 80.
Please post full output of the following command:
netstat -tuln | grep :80 | grep -q '0.0.0.0:80'
If that returns empty, try this:
This message has intentionally been placed for the reason that if you do it wrong with DNS-based Filtering, adblocking might not work.
It works for your setup, all is fine then.
Thanks!
Just checked with my RT-AC66U: Reset settings, minimal configuration and installed again without an error.
The above posted netstat commands returned correct.
What services other than AB do you run on this router?
And the new update times are in use, good to see!
Edit: and since this looks like a new install, you got warned about having no label on your USB device...
Yep got the warning about the USB
Thanks again for you EXCELLENT program. As I keep saying to my wife, good things come in small packages!
One question: I am running Merlin FW 380.65_4 on my 88U, yet after I enabled the new FW check in AB, I got an email telling me that 380.65_4 was available. As I was already on that version I thought it was unusual.
Did you use the test function in that menu?
If not, then this must be firmware related as AB only creates the script, not the actual trigger to send it.
I installed everything from 0 and its working ok, Never messed up with the pixelserve, do I need to export the certs to all mobile devices and the desktop?
Not necessarily, depends if you see errors.
I never need to, for some reason...
DOH. Guilty as charged. [emoji3]
Just upgraded via CU and everything completed flawlessly thank you sir!
