MarioCaires
Oh I see, makes sense now. Thanks for explanationIf you want to whitelist the domains that serve ads on the androidpolice.com website, you might as well uninstall AB-Solution.
My ad-blocker does not work on a per domain basis not-to-block.
Rather it blocks the domains that serve the ads, globally for every content that goes through your router to your devices.
The Android Police Website uses common ads domains. White listing these domains would mean you'd practically disable ad-blocking.
Hence, there's no use to add androidpolice.com to the whitelist and AB declined to do so because that domain is not blocked in AB.
