maghuro
But less penetration, isn't it?No. But in the EU channels 100 to 140 have more output power than 36 to 64 so try using those.
There would be negligible difference in penetration between channels 36 and 140 if the power output were the same.But less penetration, isn't it?
I haven't quite understand.There would be negligible difference in penetration between channels 36 and 140 if the power output were the same.
Channels 36 to 64 are 200mW. Channels 100 to 140 are 1000mW.I haven't quite understand.
In Europe, are all the channels output capped or only the lower/upper ones?
Understood.Channels 36 to 64 are 200mW. Channels 100 to 140 are 1000mW.
Yes, so you would have to test it. I use channel 124 without any problems.But the handicap is that upper ones are dfs
One of the fw is the Gold Standard RMerlin gui, and the other is the ROG gui (see sig).Offtopic - I downloaded gt-ax6000 firmware zip file just to check. I've found two files, one with rog on name and another without.
What's the main differences, besides the color of the pages?
Hello, thanks a lot for this useful information! I have just improved the signal level at my desk from -65 dBm to -53 dBmChannels 36 to 64 are 200mW. Channels 100 to 140 are 1000mW.
Yes, but besides the color is there any other changes?One of the fw is the Gold Standard RMerlin gui, and the other is the ROG gui (see sig).
The difference can be seen in the fw name.
@Smokey613 You are preaching to the choir. I learned (or was taught) to keep my "toys" out of The Wife's view. I have (or was allowed) a home-lab closet in which to store my necessary networking tools![]()
Most of my networking toys are out of view but Asus routers need good air circulation, hence the reason it is in plain view, that and it is very near where both ISP drops are.One of the fw is the Gold Standard RMerlin gui, and the other is the ROG gui (see sig).
6000 has an additional 2.5Gb Ethernet, all antennas external, and form factor.Yes, but besides the color is there any other changes?
Thank you for the clarification.@maghuro was asking about differences in firmware options for the same GT-AX6000.
I installed ROG version for testing. I want to change to the regular blue GUI.ROG theme is experimental. Use the regular blue GUI theme.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
